Started the PMF work, did I ever mention that I hate ironing? This was the largest ironing operation I have ever done! The canvas was mostly wrinkle free but it was folded in half on the bolt to there was a strong crease down the middle. I used a partial sheet of maple plywood as an iron board.
I chose to do the large sides first because the corners will wrap around about an inch on the front and rear, about 5 inches on the top. I want the front to lap over and finally the roof to cover it all.
I did the work myself so I rolled the canvas up and hung it from the camper using some wire. This allowed me to work in sections as I moved top to bottom. I'd roll it down lift it back up, apply the glue, bring it back down and press in to place.
**This section is for all of those new PMFer's out there. I never really found this type of information and here is what I learned "real quickly"
1. You do not have much time to work, do 12"-20" at a time max
2. Have a large spray bottle full of water handy and use it often. Keep your roller wet, spray water on the glue, in the tray before you add the glue etc. This prevents clumping and keeps the glue "workable".
3. Don't apply too much glue to the wood, this will cause what appears to be bubbles but it's really a bunch of glue. Cover well but smooth it out before you apply the fabric, a thin coat is good, don't think you need a bunch.
4. When you start to press each section out start at the center top, pulling from the bottom while you work your way down and out to each side. If you don't do this you will have bubbles/wrinkles and other issues. Center, top to bottom and out as you go.
5. It's not that hard if you follow the basic advice above but you are going to have a few bubbles etc. Those can be corrected (see below) so don't fret!
I did have a few air bubble varying in size from 1" to 3" and I found an easy way to fix them! Spray the area with water, then roll on a good dose of glue and using a wide flexible blade press it flat over the area and work in a circular motion over the bubble until the glue starts to set up and hold it down. The air will work out and the glue will work in under the fabric and adhere it down removing the bubble. No need to penetrate the fabric etc.
I used a smooth foam full size roller cover, plastic sheet rock taping knife set and masking tape for the job, the most used blade was the 4" followed by the 6".
Here are some photos of the progress:
Almost half way done with this stage, I hope it keeps going this well. I do think these 2 sides are the hardest part as far as PMF goes.
