Time is Liquid (Part 2)I have built 3 of the 5 interior "furniture" pieces that will support the walls.
For the internal "furniture" I am using 3/4" plywood that has been ripped to 1 1/2" wide, with pocket holes and glue.
These will be faces with the scraps of the 1/4" birch panels that are left over from cutting out the windows and doors from the completed walls.
I have worked out a design for the front bunks that should add rigidity to the build, and privacy / functionality to the bunks for the kids!
- Current Bunk Concept
- Oct Update Bunk Idea (Phone).png (58.22 KiB) Viewed 1610 times
It will also give me a great place to use some of the Black Walnut boards that I was gifted as trim!
The two "walls" will be 3/4" birch ply, finished on both sides. These will attach directly to the exterior walls to provide good vertical support. The green sections are storage, with the one on the right being the "garage" and only accessible from outside. The one on the left will only be accessible from the top, which will be storage for blankets and bedding.
The blue (lavender?) color is the support for the queen size bed, as well as the housing for all of the electrical and battery systems.
The orange in the middle will be the housing for the AC unit, as well as two cubbies for XL milk crates for the kids storage. On top of that will be a home made butcher block counter made from oak/hickory from our family property.
- 12v Fridge compartment
- Oct Update Furniture1 (Phone).png (204.47 KiB) Viewed 1610 times
Inside the door, across from the "garage" will be a small compartment to store our 12v Fridge. This also doubles as more support for the queen bed.
- Furniture layout
- Oct Update Furniture2 (Phone).png (380.2 KiB) Viewed 1610 times
You can just make out the furniture I have completed in this pic.
A = Fridge compartment
B/C = front lower bunk storage sections.
You can also see the front "curb" I have added to the frame to act as a support for the roof/ceiling. It will also help give some physical support to protect any coolers or water jugs from smashing through the front wall of the camper "Kool-Aid Man" style should i need to perform any brake tests!
I am hoping to get back out to the garage and work on the camper some more this weekend! Watch this space for more updates!
