Simple_Abound wrote:Very nice build. I believe a homemade door can be just as nice if not better than a factory door.
Thanks! I will do a detailed construction of the door.
pchast wrote:Looks Great so far.....
MonteQuest wrote:... One of the first things I've learned is that little items add up quickly in both weight and cost. I'm hoping to stay under 850lbs in weight and under $4000 in costs.
pchast wrote:Should be no problem if you keep track.
but will the hinge extend on the ends to keep water out?
steve cowan wrote:Great documentation and really nice work.Not knowing how you are finishing the hatch but will the hinge extend on the ends to keep water out?
