5 x 10 Squaredrop Build - Timberline
Re: 5 x 10 Squaredrop Build - Timberline
Postby mmccrumb » Thu Nov 28, 2024 9:35 am
Got the fenders painted and installed. Quite happy with the color combo.
Windows installed as well. This is the fire egress window, both salvaged from the donor trailer.
With some doorbell wire, moved the diesel heater control panel to the inside of the trailer and it works! It was only 45 or so outside but I turned it on while doing some interior work, and at almost the lowest setting it warmed things up quickly! Carbon monoxide detector and few coat hooks up, to keep us safe!
Getting close!
mmccrumb
Postby mmccrumb » Thu Nov 28, 2024 9:39 am
With some matte finish Mod-Podge, I’m putting a picture collage in the front area. Pictures from our hiking, backpacking, kayaking, canoeing, camping adventures. Can’t wait to add more from using this trailer.
mmccrumb
Postby reaver » Thu Nov 28, 2024 12:05 pm
mmccrumb wrote:Image
Getting close!
I did a similar setup with my diesel heater. When wiring my trailer, in pre-ran 3 16ga wires to where I wanted to mount the controller. I used a 5 pin, 25A aviation plug to connect power to the heater, and carry the controller signal back to the panel, since my heater is mounted in an external box that I remove in the summer.
reaver
Images: 6
Postby mmccrumb » Sat Nov 30, 2024 11:06 am
Getting close!
That is brilliant! I ran 16 for the power, but mine is permanently installed. Great idea, and way to think outside the box.
mmccrumb
