A folding wooden camper
Re: A folding wooden camper
Postby OP827 » Tue Apr 22, 2025 6:21 am
Glad to see that the window supports did fit within the wall thickness :thumbsup:
OP827
Images: 414
Postby Paintsalot » Tue Apr 22, 2025 9:00 am
OP827 wrote:Glad to see that the window supports did fit within the wall thickness :thumbsup:
Thanks, same here. Here are interior shots. Window screen will sit in recess and clip in. The screen will have to stretch a little at latch.
Build Journal for the Folding Wooden Camper here: https://www.tnttt.com/viewtopic.php?f=50&t=76513
Paintsalot
Images: 71
Postby S. Heisley » Wed Apr 23, 2025 9:35 am
Okay, now that I've totally reviewed the slidavan build, I understand what you're doing and am not so worried about your build. Go for it! :thumbsup:
Postby Paintsalot » Wed Apr 30, 2025 10:00 am
S. Heisley wrote:Okay, now that I've totally reviewed the slidavan build, I understand what you're doing and am not so worried about your build. Go for it! :thumbsup:
Thanks for the thumbs up!
I camped with my brother and dad some last week- storms cut our trip short. I got to check out my brother’s pop up.
The next milestone is to get the low walls glued/screwed to the trailer, but I’m trying to get the hinges on first and other prep work.
This weekend I cut out 2 window openings in side walls and painted the outside.
Paintsalot
Images: 71
Postby Paintsalot » Thu May 01, 2025 7:56 pm
I tried test fitting one of the upper walls. I wanted to make sure it was going to clear the hinges at the end walls.
The upper wall is just held up by gravity here, because the trailer is leaning a little bit.
The low walls are still not glued to the trailer. I just screwed them together at the corners.
Paintsalot
Images: 71
Postby OP827 » Fri May 02, 2025 2:58 pm
Your creation is starting to take shape!
OP827
Images: 414
Postby Paintsalot » Fri May 02, 2025 4:13 pm
OP827 wrote:Your creation is starting to take shape!
Thanks- exciting and challenging. I’m seeing lots of issues. Ugh.
I think I can, I think I can
Paintsalot
Images: 71
Postby S. Heisley » Fri May 02, 2025 7:17 pm
:thumbsup: :applause:
Postby Paintsalot » Wed May 07, 2025 9:01 am
Interior pic. Voids at top of sides will be filled. 1/4” cork will cover plywood. I tested gluing cork to plywood with Titebond 2, works fine but requires pressure. I will be using books to weigh it down.
I got the rest of the walls up. The camper is close to the roof joists at back of garage- roof slants away from door. I may have to tilt trailer, or turn it around.
Paintsalot
Images: 71
Postby OP827 » Wed May 07, 2025 7:40 pm
Good progress. I took wheels off and used wooden blocks to support the frame and gain enough head room.
The camper is close to the roof joists at back of garage...
OP827
Images: 414
Postby S. Heisley » Wed May 07, 2025 10:17 pm
:SG ...Still watching! :applause:
Postby Paintsalot » Thu May 08, 2025 3:02 pm
OP827 wrote:Good progress. I took wheels off and used wooden blocks to support the frame and gain enough head room.
Thanks- That’s a good option. I’m hoping I can just turn the trailer around and put the hitch towards the end of the garage. It’s a shed roof. I have a video, but I don’t know how to load them here.
I’ve been painting a view of the Mississippi river, so no work on the camper of late.
Paintsalot
Images: 71
Postby OP827 » Thu May 08, 2025 6:34 pm
You can post youtube videos just by adding the YT link inside of URL tag like this: "[url]YT link here[/url]"
OP827
Images: 414
Garage clearance
Postby Paintsalot » Thu May 08, 2025 8:04 pm
OP827 wrote:You can post youtube videos just by adding the YT link inside of URL tag like this: "[url]YT link here[/url]"
Okay, thanks OP827.
https://youtube.com/shorts/XVPWqtLWgX4?si=vgYOgONxlERcsDdt
Here is a quick walk around showing how close the camper is to the garage rafters…. 6” or so. I was completely worn out when I shot this video, I had been working on the camper straight for two days and this was at the end of it. Lol.
Paintsalot
Images: 71
