TwilightLane Cubbie Build
Postby TwilightLane » Thu Apr 08, 2010 10:11 pm
Now to hang the springs. I used the stock bolts for this element.
And positioning the axle:
Rob & Lori
Aspen & Tundra
My Instructable: http://www.instructables.com/id/Teardro ... l-Trailer/
TwilightLane
Postby TwilightLane » Thu Apr 08, 2010 10:16 pm
But a problem popped up. The axle kept tipping off the little nub. It wouldn't seat correctly.
Here is the culprit. The bolt holding together extended too far. This stock location is _under_ the spring, not above it. One of the cubbie mods is to place the axle over the springs - which I was I cut that notch above.
So in the standard layout that bit of thread and bolt shouldn't make contact with the axle.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Thu Apr 08, 2010 10:20 pm
I had been tempted to pull off the shortest leaf from the spring anyway, so I decided to pull it all apart. A half inch socket wrench did the trick no problem.
I pulled out the short leaf, flipped the bolt:
No problem at all. This was surprisingly easy. Vice grips and 1/2 inch socket.
Last edited by TwilightLane on Fri Apr 09, 2010 10:55 am, edited 2 times in total.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Thu Apr 08, 2010 10:32 pm
Installed. Two leafs instead of three. Nubbin on top and nut underneath. (And yet more evidence that I can't use spray paint worth a darn - see the red?)
That is better:
Last edited by TwilightLane on Fri Apr 09, 2010 11:00 am, edited 2 times in total.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Thu Apr 08, 2010 10:34 pm
The CFO stops in to check status.
She's gonna kill me when she finds out I used this pic. :lol:
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Thu Apr 08, 2010 10:37 pm
The view from underneath. The threads on those u-bolts extend a lot farther now w only two leaves. Hmmmm.
You can see the bolt holding the leaves together extend through the plate.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Thu Apr 08, 2010 10:40 pm
Adding the hubs. Used a grease gun and bearing packer and it seemed to work like a charm. I ruined one of the grease seals on my first try at seating it. Good thing I ordered 4. But I figured it out and still have 1 spare. No pics bc of the greasy hands.
Rob & Lori
Aspen & Tundra
TwilightLane
Bolted on the tires.
With the tires on it's obvious those slightly longer threads sticking out under the axle aren't a problem after all.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Thu Apr 08, 2010 10:44 pm
So with the frame a lot more mobile, I cleaned up the garage a bit. A clean sweep later and back to business. I'm building the Kuffle Creek cubbie but I want to stretch it a little bit. So I came up with my own profile. Cut up a piece of cardboard to mock it up the front profile...
Hmmm. We'll see. I'll get some more cardboard to do a full body profile.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby suckerpunched » Wed Apr 21, 2010 12:02 pm
jeeeze.....I think I over simplified mine........
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby TwilightLane » Sun Apr 25, 2010 9:36 pm
Well folks, it's been a few days since the last installment. The ol' laptop crapped out and we had to get a new one. I've done a thing or two since we last met. So here goes...
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Apr 25, 2010 9:52 pm
Well I've added the flooring deck to the trailer. It was kind of a comedy of errors, but 13 bolts and a mess of construction adhesive and we have this:
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Apr 25, 2010 9:54 pm
Next step to add the hitch.
Detail. I used a big ol' bolt to attach to the frame. This is actually temporary until I get over to my buddies and weld this up.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Apr 25, 2010 9:57 pm
I swung by KC Home Trailer Supply, the RV store I'm a BIG fan of, and got two leveling jack-stands. Bolted them up through the 2x6 I used at the back end of the trailer. No sweat.
You can see the pairs of holes above each stand. Those - and the recessed holes for the bolts to the frame - will get bondo'd.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Apr 25, 2010 10:07 pm
So let's shift gears a little bit. It's a beautiful sunny day and the tulips are blooming. Let's get some action shots of the pups!
Rob & Lori
Aspen & Tundra
TwilightLane
