TinKicker wrote:Those clips look simple--how do they attach to the wheel?
bbarry wrote:Thanks! It's gloss. If I were to do it again, I'd probably go with a satin or matte finish as it would show fewer dust specks. And I'd spray it with my new LVLP sprayer rather than brush it as that introduced a number of air bubbles. The wet sanding definitely helped with that.
Brad
kennyrayandersen wrote: was taught that actually you don’t want to use semi-gloss anyway, if you want a really nice finish. The reason is that to get the semi-glossed look, the manufacturers put clouding agents into the finish so that less light is reflected. By the time you put 2-4 coats of it on your wood you start to obscure the grain detail (OK, so this is REALLY fine finishing techniques). What they said to do instead is always put the gloss on, as many coats as you need/want and then you come back and essentially put really fine scratches on the outside, so as not to reflect the light so much, but also not obscuring the detail of the wood. You can do it with the really fine steel wool and Woolwax like I was saying earlier or you can go crazy with pumice and rottenstone (but that’s even more work!). The Woolwax method comparatively looks good and is pretty easy to do.
Mark McD wrote:My personal favorite:
Do your best and caulk the rest.lol.
Looks great... like the use of low voltage landscape lights... easy to get, cheap, and look sharp. Nice.
Senior Ninja wrote:Brad,
Way to go. My thoughts exactly.
Mine has three coats of varnish inside and out. Of course I love the smell of varnish in the morning. lol Grew up in the family paint manufacturing business. Even the floor has three coats on the bottom, none of that gooey black stuff for me.
