Michael
Sent from my SM-N950U using Tapatalk
Right on Brotherman. You know that's right!
Here's what I've concluded: Anytime you can spend the night in your own creation, it's a good night! Overall, it was great. I went out a couple hours prior and turned on the ceramic heater. It was still a bit chilly when I went in, so I lit the cooktop for about 10 minutes and broke a sweat. The rest of the night it was the ceramic heater only and even with temps in the negative teens, I was comfy! She holds the heat great! I had some frost on the inside of the Stargaizer windows but not too bad. I thought the walls would sweat but they didn't at all. The fantastic fans did collect condensation inside the lids and by morning had started to drip. I gave them a quick wipe and turned them on for a sec and all was well again. As tac422 said, always crack a window for ventilation. I slept like a log and so did the dog! And dang it, coffee is always better the Astroliner way!Aguyfromohio wrote:So how did the arctic overnight test go?
Inquiring minds want to know....
It's actually pretty amazing, really. I can't remember what the R-Value of the foam was, but there's 2" pink in the roof and 3/4" foil backed in the walls. The little heater ran all night but it was -10 and beyond all night with winds whipping! What do you do if you have no electricity?Aguyfromohio wrote:Thanks for that update Michael. Good to know a couple thin plywood skins plus foam insulation does the job.
Atomic77 wrote:[quote="What do you do if you have no electricity?”
Yes, I've looked at those but it seems the cheaper ones aren't very quality and the more expensive ones are out of range for me. Anyone use an Olympian heater?crpngdth2001 wrote:Atomic77 wrote:[quote="What do you do if you have no electricity?”
Maybe one of the 12V diesel heaters? Anywhere from $150 for the knockoffs on eBay up to $1,500 in the Espar or Propex models.
Atomic77 wrote:It's actually pretty amazing, really. I can't remember what the R-Value of the foam was, but there's 2" pink in the roof and 3/4" foil backed in the walls. The little heater tan all night but it was -10 and beyond all night with winds whipping! What do you do if you have no electricity?Aguyfromohio wrote:Thanks for that update Michael. Good to know a couple thin plywood skins plus foam insulation does the job.
Have you ran the A/C yet?Aguyfromohio wrote:Atomic77 wrote:It's actually pretty amazing, really. I can't remember what the R-Value of the foam was, but there's 2" pink in the roof and 3/4" foil backed in the walls. The little heater tan all night but it was -10 and beyond all night with winds whipping! What do you do if you have no electricity?Aguyfromohio wrote:Thanks for that update Michael. Good to know a couple thin plywood skins plus foam insulation does the job.
I'm still finishing up construction so I can't yet speak from experience.
But we have a high amp DC power line run from tow vehicle to the trailer that will power a little ceramic heater or the air conditioner, if we let the car idle to provide power. We looked at propane furnaces but they take up a lot of space (2 cubic feet) and cost a lot of money (more than $700).
