today's construction finally made my project a TD, and not just a project! it's so good to see it take shape.
the floor, walls, and spars went up today. everything is nice and square and there were no issues (like i was fearing). i've been working under the awning of our travel trailer because it's been so hot!
i need to get a jockey wheel for the front. it almost came off the jack today while i was underneath bolting the floor to the trailer. i still need to cut the bottom forward spar because it will have a few complex cuts in order to accommodate the headboard i'm putting in.
that black stuff you see on the rear edge is the sealant that i coated the entire lower surface of the floor with it. i've never worked with this stuff on large surfaces...it was like frosting a cake with stinky black frosting.
the infamous swoop. i'm going to try the drain that i drew above because when it comes down to it, i'm a form over function kind of guy.
