Sly1990 "Cmd Post" UPD 07-19-10 - 120V Electricity
Postby Wolffarmer » Sun May 23, 2010 10:29 pm
Hey, now you have some insulation to put in your home at home.
Wolffarmer
Images: 309
Postby sly1990 » Mon May 24, 2010 7:27 pm
:lol: :lol:
I;d need a house first...
Maybe i could start my house from the 2" foam sheet... :lol:
Today I bought :
3x 120VAC Plugs assy. 10$
2x Glue Tube King Size 21$
1x PVC 3/4"x10' pipe 4$
1x 4'x8'x1½" Blue Foam 28$
1x 4'x8'x½" Plywood 24$
1x Hole Saw 1" Kit 20$
Total : 107$
Grand Total Yet : 761$
Finishing the 2nd exterior wall.
Placing the Vent and electricity pipes. (From front cabinet to back cabinet)
The GF trying to hide herself while i'm posing my creation... :lol:
Me sweating like a wet towel... That day was SOOOO hot....
Makes me think of installing a AC inside of it... I found some cheap 6000btu 120V 5.3A at local store under 100$. I'ts supposed to cover 150sq/ft. So, it should not be a prob for only 45 sq/ft
Just need to think where I could insert it....
I'll be sufficient with the electricity....
I already have a 1800W industrial inverter, ANL Fuse and Holder, a 25A charger and a Blue Sea Fuseblock.
A Group 31 Battery (DC31-280 Big Red) is also on the way.
At work, I can buy any marine wiring/switch/accessories at their cost. (Finaly a good news.... )
The cabin is on a dolly. the real trailer should be 1ft higher.
As you could see previously, I'm very limited in working space... :thumbdown:
Yet, I did not encounter any major issue while building.... but it's not done yet.... :worship:
sly1990
Postby Ageless » Mon May 24, 2010 7:53 pm
With the white Crown Vickie; gotta put a fake light bar on the TD
:rofl:
Ageless
Postby sly1990 » Mon May 24, 2010 7:58 pm
... and a vinyl sticker writen "Command Post" on the sides... :lol:
sly1990
Postby sly1990 » Sat May 29, 2010 8:40 pm
DAY 05
Today I bought :
NOTHING :lol:
I already had everything on hand to keep going.
1/4"x4'x8' One side sanded spruce
Starting the Interior Wall.
Doing the other side....
sly1990
Postby grizz » Sun May 30, 2010 2:16 am
Love the fact that so many people on here have their builds on dolly's.
You have progressed well.
Command Post sounds like a good name , even for a Teardrop. :lol:
Greetings from England.
Rian.
grizz
Images: 29
Postby sly1990 » Sun Jun 06, 2010 12:41 am
DAY 06
Today I bought :
5x - 2"x1"x10' Pine 35$
1x - 11/16"x10"x36" Laminated Pine 10$
2x - 11/16"x20"x72" Laminated Pine 80$
3x - 11/16"x16x48 65$
3x - 4'x8'x1/8" Masonite 30$
4x - 3"x7' PJT floor frame 16$
2x King size (850ml) Glue Tube 20$
Semi Gloss Varathane Varnish (Oil Based) 20$
Wood Putty 9$
Carpenter glue 9$
Total : 294$
Grand Total Yet : 1065$
My new cabinet builder best friend... (Borrowed from my dad)
Unfortunately, I accidently dropped the Vent.. so I broke plastic the cover.... Will need a replacement for 10$
First Varnish coating.
I will need to buy a Gallon.... 1L will certainly not be enough....
I plan to apply 4 or 5 more coating.
Fixing the 1st Interior Masonite piece.
Roof cutting for the Vent.
Tomorrow, I Should be able to finish the tv Interior Cabinet and maybe the roof insulation.
sly1990
Postby YuGun » Sun Jun 06, 2010 1:28 am
İt is going well
YuGun
Postby sly1990 » Sun Jun 06, 2010 9:43 pm
Thanks... :D
Today I Bought:
1x 4'x8'x1½ Blue Insulating Foam sheet 28$
1x PVC Pipe 4$
3x PVC "T" 2$
1gal Semi-Gloss Varathane 1000 Varnish. 40$
1x Expanding Foam 8$
1x 11/16"x8"x36" 9$
Total : 91$
Grand Total Yet : 1156$
It's foaming a lot.... :?
The whole thing being sealed
Interior View (After sanding the 1st coating with 120 grit)
Interior View
As you can see, I already cut my cabinet side walls.
Rear View.. (Half Varnished) :lol:
I did not had time to finish the Cabinet/TV Emplacement
I was lazy and tired today.... and was missing a 11/16x16x72" to complete my cabinet.
Local Store was out of stock... :x
More to come next week...
sly1990
Postby sly1990 » Sat Jun 12, 2010 11:35 pm
This week I Bought :
For discretional reason, I wont enumerate the price of each items.
I paid a special Employee price wich I should keep secret...
1x Blue Sea Auto Charging Relay
5x Blue Sea Contura Switch w/ Led
1x Blue Sea Contura Momentary Switch (For Inverter Control)
2x Blue Sea 100A Bus (Pos/Neg) (Will require 1 more)
4x Lighter Plug (Marine) Female
100' 16-2 AWG (RD/BK)
65' 14-2 AWG (RD/BK)
24' 10-2 AWG Marine DC
24' 12-2 AWG Marine AC
8' 8 AWG Black
8' 8 AWG Red
Total : 300$
Grand Total Yet : 1456$
Installing all the needed Wires
Taking a look at the general disposition in the rear section.
Under Cabinet Led Ligthing
DC Charging Wire #10-2 AWG Marine (Car has a #4 AWG in the trunk.)
AC Outlet Wire #14 AWG Marine (Front 120v outlet)
DC Power Bus (Front) (12AWG - 25A) *For Ham Radios and front 12V Outlet.
Rear/Front Speakers
Dome Light
Side Marker
L Door Ext. Light
R Door Ext. Light
Future Solar Panel Charging Wire (#14AWG)
sly1990
Postby sly1990 » Sat Jun 12, 2010 11:41 pm
I Started the TV/CDPlayer/Switch Panel Cabinet.
After the 1st Varnish Coating. (2nd on walls)
It was 10PM... It's a little dark... That's it for today.
This is what I used...
sly1990
Postby sly1990 » Sun Jun 13, 2010 9:31 pm
Today I Bought :
2x Richelieu Hinges 12$ (2 Pairs)
2x Door Handle 6$
Total : 18$
Grand Total Yet : 1474$
My first try doing a Cabinet door...
Everything went well... ;)
With a Saw Table, I made 2 track side to side.
I removed some imperfections within the track with a Wood Knife.
The saw blade is 1/8" wide and my spruce plywood (from leftovers) is 1/4" Thick. :thumbsup:
Glued the whole thing together.
Varnishing....
Started the Main Panel...
I only cutted a space for one of the switches... It's not as good as I expected...
The Pine chipped around the switch hole. I guess a Black Plactic or Fiber Plate would be a better idea....
Will think about it next week-end...
Global View with semi finished Main Panel... :lol:
Also, I installed temporarely the Front Speaker Panels to see what it looks like.
Needs 2-3 more coating and the plate stated above...
On this Panel, I'll have :
1x Radio
1x Aux Input 2 (RCA Stereo Input)
6x Switch (Int/Ext Light, Radio, Inverter)
2x 12V 15A Outlet
1x 120V
The Hinges... :D
sly1990
Postby sly1990 » Sun Jun 13, 2010 10:45 pm
Sweet Mercyful Crap...
When will the 3rd page come up???
This page is now kinda heavy.... :cry: :lol:
certainly not 56k friendly.... :?
sly1990
Postby High Desert » Sun Jun 13, 2010 11:29 pm
15 posts per page...almost there ;)
Build is looking good. You can break up the pics into 2 or 3 posts to spread it a bit. But pics are good :thumbsup:
Shaun
High Desert
Images: 27
Postby teardrop_focus » Mon Jun 14, 2010 11:02 am
sly1990
:lol:
I was beginning to wonder about that, too. :dancing
I like your build so far! You have the perfect tow vehicle for the Command Post, that's for sure. :thumbsup:
You had commented,
Are these two different thoughts? Or are you thinking about trying to run an AC unit through an inverter? A Group 31 is a big battery, yes, (+/- 70-something pounds) but it won't run an AC unit for very long.
:scratchthinking:
Forgive me for assuming anything... :R
The best of luck to you on the rest of your teardrop build! :thumbsup:
teardrop_focus
Images: 127
