She's the girlfriend, so no need to obey her yet. (hope she never reads that)
I clicked on your profile and found a few pictures of you build in progress, but where would I look to see the finished product?
Looking at the pictures of your build it looks like you built your framing to very specifically define where the edges of the skin materiel will end up. On mine the frame on the 3 dimensional curves is only there to give a general idea of the curve and once the skin is on I will put laminated "beams" in place in the front corners that follow the curve that the skin makes to add a bit of extra strength.
After playing with the curves last night I decided I will use one piece of hardboard on the roof for extra rigidity and to hide my uneven cuts on the rafters and one piece on the bottom 32 inches of the front of the trailer to add extra strength in case a rock get kicked up into it. Then the whole trailer will be skinned in unpainted aluminum coilstock using this method http://serroscottycamperenthusiasts.com ... gfinal.pdf for the lower 32 inches and the majority of the roof and then the front and rear 3d curves will be strips of 6 inch wide aluminum riveted together like the wood is in my last photo with my model showing of the camper.
Once the skin is on I will then either have insulation sprayed in or use styrofoam and great stuff to insulate it. For windows I plan to build Wiley windows viewtopic.php?f=2&t=51721
I plan to put a 6 inch drop floor in the trailer so I will end up with 5'10" headroom which I was planing on 6" but somewhere I lost two inches.
I also plan to make it removable from the trailer so I can use it as an iceshack and so I can still have a flatbed trailer. Also I plan on using it for setting up my laser engraving equipment when I go to craftshows. And many times when you set up at a craftshow they give you a 10'x10' foot spot and not one inch more so the body of the camper is 9'8" and the tongue is removable by pulling 4 pins so I will be able to fit in a ten foot spot.
I haven't decided how I am going to hinge the rear cargo door yet, No matter how I hinge it I can see it being a problem in some situations.
I plan to skin the inside with 1/8 inch door skins with a couch that folds into a 3" wide bed in front and a table/seats/bed in the back. The table would be mounted on the rear cargo door so when the table is removed the door can be opened and I will have a 4 foot wide isle way in the center of the trailer that I can us to haul cargo with. Both ends will also have overhead cabinets. On the drivers side I plan to build a small closet/dresser and counter top. I think that the furniture and cabinets will act as bulkheads and add a lot of rigidity to the camper shell.
When it comes to removing the camper shell from the trailer that should be very easy. Here is the plan
Unbolt the shell from the trailer. Lower the tongue of the trailer to the ground so the back of the trailer goes up. Put blocks under the rear corners of the camper shell. Lift up on the tongue of the trailer so the front of the camper shell is about 8 inches higher then it would be when the trailer sits level. Block up the front of the camper shell. Roll trailer out from under camper shell. Then mount the snow skies under the camper before lowering it off its blocks.
