Woodrow's Build
Re: Woodrow's Build - the profile 11-26-12
Postby bjeppson » Mon Nov 26, 2012 5:34 pm
Worked on the cutting the profile over Thanksgiving. I guess it resembles a Ken-Skill though not totally.
Bob
Woodrow's Profile
bjeppson
Postby Junkboy999 » Thu Nov 29, 2012 12:55 am
I like it. :thumbsup:
Junkboy999
Images: 52
Re: Woodrow's Build - Back at It 3-19-12
Postby bjeppson » Tue Mar 19, 2013 12:10 pm
Well it has been mui cold and build activity has been at a standstill. I now have the base glued using tite bond III and using West System g-flex for sealing the joint. It also has two coats of CPES all around. I think once I get it mounted to the trailer frame things will start moving again especially with warmer weather. I do better with cutting and fastening wood than using epoxy.
This started as a project for my daughter and it appears it will now be a wedding present for her. Got to get off of my back side and build it.
Bob
:D
bjeppson
Re: Woodrow's Build - the profile 5-4-13
Postby bjeppson » Sat May 04, 2013 4:22 pm
I fastened the 5/8" plywood to the frame once I treated it with CPEC. I made some "floor joists out of 1 1/2" material so I could use 1 1/2' rigid foam insulation in the floor then added a 1/2" subfloor leaving 3/4" around the perimeter so the side walls will have a built-in rabbet joint I used 3/4" grey pvc conduit as an electrical chase between the friont and the real of the teardrop. This will make it easy to fish the electrical lines from the battery to the power panel and the trailer wiring harness. I am using pocket screws to fasten the side wall structural "ribbing". One layed out these will be unscrewed, apply glue to the joint and re-screw the pocket screws.
Here's a photo.
beginning of sides.JPG (84.24 KiB) Viewed 1005 times
Bob
bjeppson
Postby bjeppson » Sat May 04, 2013 4:32 pm
Picture of floor insulation.
floor insulation.JPG (108.69 KiB) Viewed 1005 times
The gray pvc conduit as a electrical chase is on the top edge of this sideways photo.
bjeppson
Re: Woodrow's Build - 5-15-13
Postby bjeppson » Wed May 15, 2013 3:55 pm
Here's the latest:
ac back.JPG (57.2 KiB) Viewed 963 times
floor insulation.JPG (82.35 KiB) Viewed 963 times
beginning of sides.JPG (84.24 KiB) Viewed 963 times
bjeppson
Re: Woodrow's Build - 5-15-13b
Postby bjeppson » Wed May 15, 2013 3:58 pm
Rear bulkhead.JPG (90.08 KiB) Viewed 963 times
bjeppson
Re: Woodrow's Build
Postby KCStudly » Wed May 15, 2013 5:32 pm
Nice wood. :thumbsup:
Quality looks good! :thumbsup: :applause:
Re: Woodrow's Build
Postby bjeppson » Tue May 28, 2013 4:57 pm
Built the galley hatch between yesterday and today. It wasn't as bad as I anticipated but then it still doesn't have the skin and too early to tell about leaks. One thing at a time. Titebond III and pocket screws are great.
Bob
Galley Hatch Structure.JPG (78.1 KiB) Viewed 898 times
bjeppson
Re: Woodrow's Build July 14
Postby bjeppson » Wed Jul 09, 2014 1:47 pm
Got motivated and have been wiring. Have 110 to cabin and galley, have 12v to cabin and galley plus interior 12v lights, porch lights, reading lights and fantastic fan.
Bob
bjeppson
Postby bjeppson » Wed Jul 09, 2014 1:50 pm
Fenders arrived from Grant, I had them painted at a local body shop. They will be the last piece on though they are already fitted. You can see a piece of one of them sticking out of the end of the box in the cabin picture above.
Bob
bjeppson
Re: Woodrow's Build - July 2014
Postby bjeppson » Wed Jul 09, 2014 1:53 pm
Sides were coated with 3 coats of West System epoxy and then 4 coats of marine varnish with UV protector. Sanded between coats.
Bob
bjeppson
Re: Woodrow's Build
Postby SLUG36 » Wed Jul 09, 2014 2:56 pm
I LOVE THE WOOD SKIN ON YOUR BUILD!!
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Re: Woodrow's Build
Postby oakinteriors1 » Wed Jul 09, 2014 3:15 pm
WOW " bjeppson" you are around the corner from me....I'm in Bates City....
oakinteriors1
Re: Woodrow's Build
Postby bjeppson » Wed Jul 09, 2014 3:52 pm
Thanks,
Wood skin is 1/4" ply glued to a skeleton frame. Used 1 gal milk jugs filled with water for the clamps (8lbs/jug). The trim around the door and top is 1/8" - 3/16 cherry. Skeleton is poplar.
Bob
bjeppson
