OK, so I had about 4 hours this afternoon to work on the TD. This week, because I have no plans and I'm kind of drifting along, "winging it", I changed course. I'm now going to use the 12" wheels on the next BBQ smoker I'm building and I've bought three 16" 5 star Ford Mustang wheels for the TD.
I managed to "stretch" the plywood to achieve the 52" width and allow for the 108" length. Using Oak to support the joint added a lot of strength. 2 coats of Spar/mineral spirit mix to the bottom of the deck and tomorrow, I'll apply a liberal coating of "Liquid Rubber to the bottom of the flooring.
Because I'm going from a 12" to a 16" wheel, I'm going to have to build a new axle. This new axle utilizes a 4" drop spindle and I'm going to install it on top of the springs to keep the deck height below 15".
The axle build here is the lazy man's build.... i.e., I'm welding up one side, mounting the hub, wheel, and u-bolt kit to get my accruate deminsions, then I'll replicate to the other side. Due to the odd dish on these wheels, this saves me a lot of time on tha axle build and simplifies things.
For tomorrow, I'll get the rubber on the bottom of the deck and get the deck mounted on the frame. I should be able to get my side designs cut out... and get my 1/2" plywood hollowed out and insulation cut! NO HURRY but I have to work Darlington Raceway, Mothers Day Weekend for the squadron on base (fundraiser for the Christmas Party) and this WILL be my sleeping arangement! So whether it's done or not, It has to be sleepable in 8 weeks!
