Well I made it
. From trailer frame to camping in 40 days. Here she is on her maiden voyage
Cabinets are not done and it has a temporary door but it kept us dry and comfortable for a week!
I haven't posted in a while because I was working on the trailer until one or two in the morning every day for the last three weeks. With two weeks to go I had the walls up (glassed and epoxied) and was busy installing the roof, front, and hatch. Enclosing the back was a real pain in the you know where! especially the transition between the angled sides and the straight hatch opening
One week before camp-day I finally rolled here out of the shop. Here my brother is welding the tongue on
I didn't have room in my shop so I moved her down the road to a friends place to glass the ends. I glassed the ends, lapping around the corners onto the side walls. The roof was glassed at the corners only since the flat top is plywood and I figured epoxy alone was enough.
I did the filler coat of epoxy on Wednesday, glassed the ends and hatch lid on Friday morning, then rolled her out and installed the windows and doors on Saturday afternoon. I only had time for the single coat of epoxy and the weave of the glass was still visible. Of course it rained all saturday night and most of Sunday (the day we left). I ran out of time and made a temporary side door Saturday night... installed on Sunday morning
Sunday evening when the camper finally dried out the two day old epoxy was all cloudy and looked awful
Apparently 30 hours of curing time is not enough to handle two days of rain. I was pretty worried but kept telling myself it would be OK... since the water wet it out I figured a fresh coat of epoxy would do the same!
When we got home on Saturday I rolled her right into the shop and pulled the hatch off. After a good sanding and fresh coat of epoxy about 90% of the problem was resolved. There is still a little haze in some areas and a some of the nail dimples are kind of white. It looks great from 20 feet! Good enough isn't a term I use often when it comes to my woodworking projects but I dread the thought of sanding off all that glass and starting over. I'm going to do the same to the front (the roof will be painted)... it will have to be good enough.
I'll post some more pics as I get the cabinets installed and finish the final epoxy and varnish coats.
Chuck
