I finally got the opportunity to get all the components built thus far and install them on the trailer for a final fit. The framework dropped right into place on the trailer and a few taps with the rubber mallet seated it nicely. The hardware for the top has not been installed as yet so we set the platform on the frame in two pieces shown here in the folded position.
- 2013-08-04 13.31.14.jpg (14.79 KiB) Viewed 411 times
After that we opened the platform and centered it up so I could get up there and strength test it. The framework & platform are very strong and light with no movement at all.Everything in the platform system, including the tent probably weighs less than a full sheet of 3/4" ply.
- 2013-08-04 13.33.18.jpg (13.87 KiB) Viewed 411 times
Once I was satisfied with how everything will line up it was time to pitch the tent. The tent I am using right now is a Eureka 5x7. It was cheap and available and it will allow me to shorten up my timeline to completion. The permanent tent for this build is an OasisII. The OasisII was purchased without any hardware so all of the mounting apparatus will have to be fabricated. Here is the Eureka on the platform.
- 2013-08-04 13.47.54.jpg (10.44 KiB) Viewed 411 times
While I was on site I pulled off the rollers so I could clean up the wheels and mount new tires. The wheel bearings will also be re-packed next weekend, just as soon as I return from a couple of travel assignments.
"Problems are only opportunities in work clothes." - Henry J. Kaiser
