KISS build (updated 3/29) with pictures!
Re: KISS build (updated 2/18) been a while..
Postby Nate.petty » Sun Mar 02, 2014 3:54 pm
Now if you look real close you might notice that I technically have it on backwards... does anyone have any objections to this? will this be a problem in any way? or should i turn it right way?
Nate.petty
Re: KISS build (updated 3/2) with pictures!
Postby mezmo » Sun Mar 02, 2014 11:19 pm
It all depends on what you were going for - a traditional
looking TD or a 'Reverse TD'. It appears you do not have
a galley so that's not much of a consideration. Since you
only have one door it is probably better to either take it off
and turn it around or [probably much easier] cut another
door on the other [curb] side. TDs with a door on each side
are just so much more convenient to access and use. If you
are in a campground with hookups, most are set up for the
"drivers/road" side of the RV/camper and only one door positioned
on that side would/could just put you in the middle of all
that instead of opening out onto the campsite. Another
consideration for a door on the curb side is if you needed
to access the TD's interior in a situation where it wouldn't
be safe, due to traffic, to access it from the drivers/road side.
Norm/mezmo
mezmo
Images: 194
Postby Nate.petty » Mon Mar 03, 2014 10:12 am
Ahh. I didn't think of all that. Thanks for the post and considerations!! :thinking:
Nate.petty
Postby Nate.petty » Sat Mar 29, 2014 8:15 pm
Got the floor studs and plywood on the floor.
Set it on the trailer the right way..,
Started on the inside floor and insulation
Started plating the top
Nate.petty
