I modified the bottom-front to increase a bit of storage space.
TL
anon1 wrote:Hi 225,
Can you please explain more about your trailer #2 rubbing on things?
Like, what part(s) rubbed the ground and how high off of the ground that part was normally sitting? Was it just at incline/decline places where the tow vehicle might be going up into a parking lot and the back of the camper dragged? Was it at speed bumps/tables/etc?
Any details and real world info you can provide is appreciated.
Thanks.
[add] Do you know what the distance was from the axle to the rear of your camper and the height off the road to the underside of the rear part that might have drug? Thanks.
rebapuck wrote:I want to know how you will pick up aluminum on a motorcycle.
mahoy78spyder wrote:Sorry to ask such a newbie question, but where did you source your axle assembly? And what weight capacity did you choose?
noseoil wrote:Another suggestion? If you're not going off-road, what about mounting the axle on top of the springs? With shackles you may have enough room and sufficient travel in the setup for clearance.
225 wrote:A while back I bought a TD template on eBay. I forgot I even bought it. So after digging through stuff I bought online when I got in from offshore, I remembered..LOL.
Since then, I never started my build because of my home brewery build and motorcycle stuff. After looking at the pics over and over, I think I'm going to use the template.
Here is the eBay link: http://www.ebay.com/itm/RV-TEARDROP-TRA ... 0738165041
And the trailer:![]()
I'm going to try to make it as much as these as possible, but with my touch. Well, here goes nothing.
