Back again. Working 7 days a week till October so time to get in the garage is hard to find.
I sealed the ceiling with a few coats of poly mixed with turps. Brought 4/ 2400 x 1200 ( 8x4) sheets of Polystrene for $40. Nice work cutting and fitting.
Cut a few slits in sheets to bend around the curve.
Then started to run the wiring.
Two reading lights, with an USB and 12v lighter plug at the pillow end, overhead light by the shelf, overhead light on hatch.
Wires will run down in the shelves through conduit to the rear where the battery will be housed.
Might need to make a polystrene cutter using a battery to trim the second layer of 20mm (3/4") Polystrene.
Got to go. Really enjoying this build so hope to be back soon.
See ya.
