by KCStudly » Thu Jul 24, 2014 10:28 am
So I'm not clear on what you are planning for the bottom of the wall and how it will be different from your test piece. Is that part that will hang down just going to be the 1/4 inch outer skin, and the 1x framing will be stepped to sit on both the frame and the floor?
If that is the case I would do as you mentioned for the walls to floor; PL and treated deck screws. For the flap hanging down over the frame I would seriously consider just sealing the gap with a good bead of caulk (I like the paintable exterior kind, not silicone based). My rationale is that this will form an adequate bond, avoids putting holes in the frame, and would be much easier to slice thru in the unlikely event that you ever have to separate the cabin from the chassis.
Be sure to seal the edges of your ply very well (epoxy, varnish, paint, The Mix, whatever).
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
