From the thread No converter just battery charger? http://www.tnttt.com/viewtopic.php?f=30&t=55957xinthewoods wrote:Here's a question for anyone reading... My new battery metered at 12.67v when I hooked it up this afternoon. I've got it on my charger now and the charger is charging. What voltage should I expect to see when it is full? I'm wondering how long it will need to be on the charger. It's a 7 amp smart charger and a 100ah battery. I'm thinking it might need to charge for a while.
working on it wrote:Hope this is my final post on this thread... First thing, I checked the battery voltage (12.8vdc, on my very accurate multi-meter), then did as I stated above, and let the charger do its "automatic" float/desulfate thing after 100% charge. Two hours later, after hovering around 15.6vdc (mostly around 15.54, as observed), the charger switched to the voltage display (= 13.4vdc), and to "std" (not AGM) and to "maintenance charge" (@ 2amps). I turned it off, repeated the steps, and one hour later, it did the same. Repeated this two more times. My conclusion is that the AGM battery, having reached 100% charge (12.8vdc being the normal full charge for AGMs) eventually reached a higher voltage than normal for AGMs (i.e.=13.4vdc). Then the charger would go to std/float at 2amps to maintain (2 amps is not the "recommended" default AGM charge). Verdict: battery saved, charger is adequate for my needs, but I will have to manually select charging state (10 amps or 15 amps, not 2 amps) as the charger fails to recognize that the AGM actually can lose capacity at 2 amp charging rate. Thanks to Dale M and bdosorn for their help and advice!
Users browsing this forum: jdeleon and 5 guests
