The word that comes to my mind, is, fascinating.
Is that the pink foam you are using?
tony.latham wrote:The word that comes to my mind, is, fascinating.
springdew wrote:Wow this is really cool. I plan to use curved SIPs in my build and thought the foam layer would have to be sculpted, based on remarks I saw elsewhere regarding green construction and foam going to waste. I can now see that sculpted foam comes much earlier in the process, in the form building stage, and, as you mention, the form can be reused for other things. If things work out, my build may become the basis of a kit that others can use, so reusability is a particularly attractive thought.
Thanks for sharing!
dales133 wrote:Love your work, very inspirational particularly the canvas and gutter parts.
I was actualy considering gutters on mine, any chance you could share a bit more info on the materials and techniques you used.
springdew wrote:I had planned to order SIPs from a provider, hadn't selected one yet. Lina got hers from Pacific Builders http://www.pacific-builders.com/sip.html but I live in a different region. I went to a link yesterday about the vacuum process and was impressed at things like the spiral staircase. This is really encouraging.
