Falcons Build, 4x4x8 ft, on a boat tr.update
Re: Chain Bolt latch for rear hatch Falcons Build, update
Postby Falcon » Sat Jan 10, 2015 6:09 pm
127744127743127742127741
Be who you are, say what you want, those that matter wont mine an those that do don't matter.
more views of my build>>>------>http://www.tnttt.com/gallery/album.php?album_id=3761
Falcon
Images: 30
Re: Falcons Build, 4x4x8 ft, on a boat tr.update
Postby Falcon » Mon Jan 19, 2015 8:12 am
127974
Just adding the last piece of cloth to my build,,helpers are Quent& Zack my grandsons
Falcon
Images: 30
Postby KCStudly » Mon Jan 19, 2015 8:33 am
Canvas job looks great! :thumbsup:
Postby Falcon » Sat Jan 24, 2015 4:46 pm
Re: covering with cloth& glue
Postby Falcon » Sat Jan 24, 2015 9:42 am
I have painted my tear to match my cj5, It has 3 coats on rustolem , what I did was first coat with a 9" x1/2" nap, 2econd with next size smaller in , then sanded to just take off fuzz with 100 grit, then the 3rd with 1/4" foam roller, ill let that dry for a month, then wet sand an spray a top coat an trim..Ill post pics tomorrow when It sees the sun for first time. 8)
Falcon
Images: 30
Postby Breytie » Sun Jan 25, 2015 2:12 am
Beautiful build. I truly like it!
Good idea in the hatch latch! How do you operate it from outside?
It may be a good idea to put a metal top on that striker block. Road vibration will cause that latch to eat into the striker block. And make sure those chain hooks are securely closed, you do not want them to come off once everything is closed up.
Experience is learning from your own mistakes
Here I make mine in public: My build
Breytie
Images: 36
Postby dales133 » Sun Jan 25, 2015 2:20 am
That looks fantastic good work
dales133
Postby Falcon » Sun Jan 25, 2015 7:50 am
Breytie wrote:Beautiful build. I truly like it!
Ill post a pic of it, its a Shed T-Handle Lock Set Chrome 4-1/2". cost about $12.00.
About eating into the block, that's oak end grain, so should hold out ok..
I have a side door. my trailer is built for hauling stuff..
Falcon
Images: 30
