Colorado off-road standy
Re: Colorado off-road standy
Postby cowboynico » Tue Apr 05, 2016 3:22 pm
The camper is done! First trip was 1300 miles with very little that went wrong. All i needed was a .5 inch wheel spacer as the tires rubbed a little when the suspension was flexed out through some of the sandbars.140777
I think I like building more than I will like camping when I am done....
cowboynico
Postby cowboynico » Tue Apr 05, 2016 3:40 pm
Here are some more pics of the finished camper. 140780140779140778
cowboynico
Postby cowboynico » Tue Apr 05, 2016 3:54 pm
Stabilizers i built up just before the trip. Worked really well!140781
cowboynico
Postby noseoil » Tue Apr 05, 2016 11:09 pm
Looks like it turned out very well, good job sticking with it! Did you get a chance to weight it yet? Congrats.
137905
noseoil
Images: 670
Postby cowboynico » Wed Apr 06, 2016 2:04 pm
Thank you. It was 95% finished for like 3 months, we had to plan that rip to make me finish it up. It was 2240 lbs with the mattress and spare tire, otherwise empty.
cowboynico
Postby rustytoolss » Fri Apr 29, 2016 12:27 pm
cowboynico wrote:Stabilizers i built up just before the trip. Worked really well!140781
Looks like the axle is bent :o . hope it's an optical ollusion
Mostly Old Parts And Rust= MOPAR
rustytoolss
Postby rustytoolss » Fri Apr 29, 2016 12:29 pm
cowboynico wrote:The next step for me was subfloor (1/2") OSB and R13 non-backed fiberglass as I couldn't afford Bluebeard.
April 23rd 2015
130985
The first wall is up and the thing is actually looking like I am making progress now.
How tall is that front wall ? and rear wall ?
rustytoolss
Postby KCStudly » Fri Apr 29, 2016 3:15 pm
rustytoolss wrote:Looks like the axle is bent :o . hope it's an optical (i)llusion
Most axles are manufactured with some bend up in the middle to provide camber.
Postby Gettin Started » Fri Apr 29, 2016 6:34 pm
Great build, congratulations!
Gettin Started
Images: 15
Postby Toytaco2 » Fri Apr 29, 2016 6:45 pm
I'm interested in your stabilizers you built. Can you share any details or additional pics about how they work and how you set them up.
BTW, I'm a Colorado (mainly San Juan Mtn) back roads junkie.
Sent from my iPad using Tapatalk HD
Toytaco2
Images: 368
Postby cowboynico » Tue May 31, 2016 8:43 pm
Front wall is about 5 feet and it is about 7 foot in the back. Stands 9'2" off the ground on the wheels. And yes the camper was bent by a friend of mine as that axle is manufactured by us us using spindles from tractor supply. The stabilizers were really easy. I will post better pics.
cowboynico
Postby cowboynico » Wed Jun 01, 2016 4:24 pm
142159
Thos is tye base plate made from 3/16" × 5" flat stock and a couple 1/4 " tabs drilled for a 3/8" pin. (I mocked it up using the bolt. The leg of the stabilizer was 1/16" 1x1 square tube. Drilled for the 3/8 pin on the bottom. On the other end you cant see i cut a notch and added a 3" piece of 3/4" angle iron to rest on the rear bumper mounts. Also i bent the base plate and welded on a large diameter nut to hook the ratchet strap into. If anyone wants more pics. Send me your email as i have a heck of a time resizing the pics on here.
cowboynico
Postby 39Ratrod » Wed Jun 22, 2016 7:29 am
It looks great! Glad to see you getting to use it, looks like it works quite well!!!! Outstanding!!
The biggest difference between a dreamer and a doer is the follow through.
39Ratrod
Images: 71
