New Zealand Teardrop build almost complete
Re: New Zealand Teardrop build almost complete
Postby new leaf » Fri Jun 05, 2015 8:25 pm
Showstopper wrote:Hi Noseoil and thanks. At this stage its at a guess it around 90-100kgs on the draw bar,but this should change with the addition of a fridge and water tank etc as these are all behind the axle. I will be getting it weighed once everything is in place and complete. I think its probably going to weigh in at about 750kg , maybe less. I made it as light as i felt comfortable. The floor is a sandwich of 7 mm tantalized ply bottom with a 40mm x 18mm batten and polystyrene between and 7mm non treated ply on top. The walls are 22mm lite weight multi layer ply with most of it routed out to save weight and allow for insulation.The inside wall linings are 2.7mm lite ply wrapped in marine vinyl and the the out side is 3mm aluminium composite. I probably over killed the hatch construction as that is made from 22mm ply and 75mm thick with nogs/dwangs about 200mm centres , So it was quite heavey. But i didn't want it to lite as it would have sprung once the outer skin was attached. I took it for a quick tow the other day behind my van which is only 2.0 litre and very slow to start with but it made no difference and teardrop towed great.
Just ready what you made the walls out of sounds a lot like my teardrop.My hatch lid is also heavy.I have not yet weighed it,hope you do that this afternoon.Will let you know how i go.
new leaf
Images: 32
Postby Showstopper » Sat Jun 06, 2015 7:03 pm
Hi there New Leaf,
I just had a quick look through your build photos, and yes very similar construction. I just cant seem to find the time to get mine finished so i can get a finial overall weight and a draw bar weight. i am hoping the weight will change a little once the fridge and water tank and waste water tank go in. But even if it doesn't change it much, i don't think its going to make a big difference to how it tows now.
Nice job on your build by the way too. I too am kinda on the North shore as well.
Showstopper
Images: 33
Postby new leaf » Sat Jun 13, 2015 6:25 am
Hi there New Leaf,
Hi
Your on the shore too wow be really cool to come over and have a look at yours.I've not seen any others close up.Do have some questions about yours.
Marcus
PS im in birkdale.
new leaf
Images: 32
Postby dales133 » Sat Jun 13, 2015 6:45 am
I'm from Northcote. .. sylvan Ave but living in aus
dales133
Postby Showstopper » Sun Jun 21, 2015 3:36 pm
Just a few pics of recent work to the teardrop
133168
Water and waste tanks in and plumbed. i used 70 liters tanks, maybe a bit much ?
133167
133166
Fridge in and wired.
And its all road legal now too :D
Showstopper
Images: 33
Postby KCStudly » Sun Jun 21, 2015 3:59 pm
Very nice. :thumbsup:
Postby Hoosier Daddy » Thu Jun 25, 2015 4:50 am
That TD is beautiful! but out of so many of the details I absolutely LOVE the wheels you have chosen!
Of all the classic style mag wheels, the slotted rims have always been my favorite
I have gone to find myself.
If I should return before I get back, please ask me to wait.
Me
Hoosier Daddy
Postby Showstopper » Sat Jun 27, 2015 8:59 pm
well its done, all registered and WOF, tanks are in and working, fridge is in and chilling the beers nice. so i thought i would get it weighed. Anybody want to guess the the dry weight.?
Showstopper
Images: 33
Postby KCStudly » Sat Jun 27, 2015 9:03 pm
1150 lbs.
Postby new leaf » Sun Jun 28, 2015 2:19 am
680kgs
new leaf
Images: 32
Postby noseoil » Sun Jun 28, 2015 6:42 am
With water & beer, best guess at 620kg
137905
noseoil
Images: 670
Postby Sheddie » Sat Jul 04, 2015 11:58 pm
Hi Showstopper, welcome from another Kiwi :EXP :shake hands:
Sorry I hadn't spotted this before now. You have made a really nice job of it :applause:
We are on the northern side of Whangarei, so not all that far away. We get down that way from time to time as my wife's parents are in Albany.
We were communicating with Newleaf recently about the possibility of a get together sometime, somewhere when the weather warms up.
Guess on the weight. We are at 620kg (everything in except food, clothing and gazebo) and have around 60kg on the hitch. Your construction is fairly similar to ours so I would say 650kg. :thinking:
Sheddie
Images: 1129
Postby Showstopper » Sun Jul 05, 2015 3:54 pm
Ok. The final weight Dry weight is 720 kg or 1583.77 lbs. I didn't think it was to bad all things considered, Tv Fridge, Battery, Tanks, Pump Etc. and i used marine ply over Construction ply, so i gained a few kgs by doing that.
Showstopper
Images: 33
Users browsing this forum: Bing [Bot] and 12 guests
