KCStudly wrote:You won't have time to build a trailer, so once you get a rough idea of the profile you will want to get the trailer in hand before you decide on much of the details or start cutting wood. Even tho they may be advertised as a certain nominal size, I would want to get my hands on it first to measure actuals. You never know what tolerances they may have been working to that day.
tony.latham wrote:Scott:
I think the floor overlap is a good idea. I do the same with my sandwiched walls. I prefer to go with a 3/4" plywood skeletanized core, and then 1/4" skin on the interior and exterior sides. So with my walls, it's the 1/4" skin that overlaps the floor. It also makes it easier when your setting the walls.
Your lapped joints will be fine without the dowels as long as you create good glue surfaces to join –and your lap is 4-6".
You might consider putting your lap joint forward of your hatch spar. That way the joint will be supported by both the floor and the ceiling. It's going to take you three sheets of plywood anyway for the two walls.
Now: after re-reading your post, it sounds like you are going with sandwiched all construction. In this photo of my last set of walls, you'll see where I stuck the skeleton joint and then butted the 8' skins over it to form the 10' wall:
Since I use Steve Fredrick's hatch method, there's a piece of 1/2" pywood that goes over the skin in the galley that really strengthens it up. Here's my better-half putting on a coat of poly. She's good at it.
but if you have any good links to that hatch method I'd like to check it out.
