by Camping Cur » Sun Jan 03, 2016 11:00 pm
The more I think on it, the more I realize that just serving 2 purposes (cargo trailer/basic camper shell) will be fine and not to worry about the removable aspect of the build. That way I can add more weight (within reason) to the shell with some interior finishes. So the outside covering weight may not be that much of an issue. The FRP panels are said to weigh 20# each. I am wondering, if I try them, whether they can be attached directly to the studs without additional under-ply of luan (or similar) ? Then cover the inside with luan for strength? Still working on the flooring and the lower sides now so have a while to go before I get to the frame and exterior covering. Building off of the 2 inch upper frame angles on the Carry-On trailer gives an additional 9 inches of height which is a plus, also adds a bit to the interior width. Filon has to be attached to sub-panels ( I think) so seems like a lot more difficult for a DIY-er to accomplish. Plus, from what I read it is very expensive. No place around here to get it, (that I know of), so would have to order it and add shipping costs.
