The Lovie Build
Re: The Lovie Build
Postby lrrowe » Tue Jan 19, 2016 12:35 pm
All the posts that are like this one show very neat gaps between the door and frame. I wish I could use the router that well.
Nice job
Bob
lrrowe
Images: 439
Re: The Lovie Build
Postby jlovell25 » Thu Jan 21, 2016 3:34 pm
lrrowe wrote:All the posts that are like this one show very neat gaps between the door and frame. I wish I could use the router that well.
Nice job
Thanks Bob... The trick is to take a lot of time with the setup. I spent an entire Saturday laying out and cutting my first door. The second one was a little easier. Routers are amazing with guides.
Jim.
jlovell25
Images: 34
Wall Skins
Postby jlovell25 » Tue Mar 29, 2016 10:01 am
I got the inner wall skins glued and trimmed. I could only get 4x4 sheets of birch locally so I had to try to hide the seem as much as possible.
jlovell25
Images: 34
Router tear-out
Postby jlovell25 » Tue Mar 29, 2016 10:56 am
I made a mistake when I first started to flush cut the door openings after attaching the inner wall skins. I had a spiral upcut flush trim bit in my router and had some ugly tear-out. After I realized what was happening I switched to a normal flush cut bit and it was much better. I was looking at making an inner door jam so I could use a double seal on the doors. Guess this tear-out issue makes the decision for me. I think I'll build a inner door jam out of oak that matches the curve of the doors and overhangs about 1/2" for the inner door seal.
jlovell25
Images: 34
Finishing the inner walls
Postby jlovell25 » Tue Mar 29, 2016 11:43 am
After a lot of reading and some testing I decided to go with (Satin) MinWax Helmsman Spar Urethane for all of my interior wood finish. The main reason I went this route was the fact that I live in Florida and we have high humidity and condensation/mold is something that will happen here. I am doing the standard three coats with a foam brush and sanding with 220 grit between each coat. The finish is not quite as hard as I had hoped but I was sort of expecting that.
jlovell25
Images: 34
Walls are up!!
Postby jlovell25 » Tue Mar 29, 2016 11:59 am
Got the walls and the rear bulkhead installed on the frame. For the glue I used PL Premium construction adhesive because I had already coated the attaching surfaces with spar urethane. I also used 2 inch coated deck screws along the floor line and again with the bulkhead. I used Kreg jig pocket screws to attach the rear bulkhead to the floor. The back side of the rear bulkhead will be inside the galley cabinets so I painted it with white interior trim paint. I will be painting all of the interiors of the cabinets with white trim paint to make them brighter inside and easier to clean.
jlovell25
Images: 34
Re: The Lovie Build
Postby ELM » Tue Mar 29, 2016 12:23 pm
As my Dad always told me for 40 years. (The trim will hide it)
My Build journal. viewtopic.php?f=50&t=65395
ELM
Images: 176
Galley Countertop
Postby jlovell25 » Tue Mar 29, 2016 1:01 pm
I got the counter top for the galley put together. I used 3/4" plywood with some off the shelf laminate from Lowes. For the edge I attached a piece of oak using a tongue and grove router bit set. After gluing up the laminate I put a small bevel on the edge with a 45 degree router bit and then applied some spar urethane to the oak. A portion of the counter will extend forward into the main cabin and become the bottom of the interior cabinets. I went ahead and laminated the entire thing. I figure having laminate on the bottom of the interior cabinets will work well.
jlovell25
Images: 34
Re: The Lovie Build
Postby KCStudly » Tue Mar 29, 2016 1:09 pm
Looking good! :thumbsup: :applause:
Re: The Lovie Build
Postby azgreg » Tue Mar 29, 2016 4:46 pm
Love the shape of the doors.
azgreg
Re: The Lovie Build
Postby TheOtherSean » Tue Mar 29, 2016 9:45 pm
Nice job! Keep up the great work.
TheOtherSean
Images: 111
Re: The Lovie Build
Postby S. Heisley » Tue Mar 29, 2016 10:42 pm
It's going to be a beauty! :thumbsup:
