Putting carbon fiber on the side walls. This was a huge step. I was a little nervous because this is by far the largest piece Ive layed up. Before this it was just kayaks and small parts out of carbon.
I filled the various holes for roof rack and wiring with silicone plugs, then used modeling clay (sanded flush) to make it flat for epoxying. Make sure to carefully record where the holes are so you can drill them out later.
Time is of the essence when working with this large of an area. I premeasured out several large cups of epoxy and wrote on them how many grams of hardener they needed so i could just drop them on the scale and mix cup after cup.
I prewetted the plywood with epoxy on a foam roller, then applied the carbon fabric taking care to not snag it too much. After much careful positioning to line up the threads, i then used a spreader to fully wet the fabric with epoxy.
