Çelebi (Che-Lebby-spelling En) Mini Caravan building proces
Postby YuGun » Sun Jan 09, 2011 10:55 am
Hello my far away friends,
Thanks to all of you,
Mike, İt can opens 45 degree it is about 185 cm up from the trailers upper point at rearest point, (At last photos you see it 147 cm lenght) That means at second floor bad someone stand up fully. But i think limit it but i dont decided how much, When iwill buy opening gas springs i will decide it.
And i wont do second floor bad at first, But i will done its prepare, Because we are two now, When we will tree we can easily attach the second floor bad.
İ hope i could explain with my bad English soory,
İ tihink i can limit it abaut 150 cm, İf in the future we add beds for children, that will be useful.
My caravans inner height is 150cm +150 cm pop up.
From outer its height to top about 205 cm+150 cm 365 cm total height with popup.
Bu i can limit it less than this that is not my final decide.
YuGun
Postby YuGun » Sun Jan 09, 2011 11:19 am
Bugün çok güzel bir gündü, Sabahtan akşama kadar güneş hiç tepemden eksik olmadı,
Ben de rahat rahat çalıştım.
Arka kapıların iç kasasını oluşturacak l profil ve lamaları keserek arka kapının karavandaki hazırlığını tamamladım,
Boyamaya vakit kalmadı ama olsun onu da haftaiçi yaparım,
Sonrasında kapıların kağıt üzerinde çizimini yaparak gereken parçaları belirleyip hepsinin kesimini yaptım,
Şimdi kapıların toplanması ve yerine montajı var sırada...
Today was a beautiful day for work, The sun never go on of me and i have worked very happy and fast, i could do the door frames of back, Then i have chop the doors steel. İ am happy today with the work i could do.
Now the next step the doors weldings and attaching. İt is slowly reaching the end.
YuGun
Postby Woodstramp » Mon Jan 10, 2011 1:42 pm
Yugun,
I was looking at one of your postings and you mentioned one delay you had was because your steel man could not cut a certain angle on a piece for you. I see that you have a 4" or 4 1/2" high speed grinder (with wire wheel and a flap-sander) discs. They also sell nice little cut-off wheels for these 4" and 4 1/4" diameter grinders like you have. These are thin abrasive wheels that work great for cutting steel. If you had some, you could cut any angle you desire, yourself. That is what I've used a lot on my frame. The best ones I've used are made by Metabo and Dewalt...they last the longest.
CAUTION...make sure to wear a full face shield, gloves and thick long sleeve shirt when using these...If you get them in a bind at full speed they will disintegrate....also make sure nobody is standing near while you are cutting with them. Other than that caution, those little wheels are great.
BTW, like the axle you have....what is it from?
Woodstramp
Postby YuGun » Mon Jan 10, 2011 7:45 pm
My main cutter is this it uses 35 cm cutter disk and a useful machine can cut main angles clearly, İ bought it here at the beginning of the second section of build. İn the base trailer i havent this, İ chopped pieces of it a steelman.
İn fact at the beginning as my first design, i dont think the wall frames by steel, because of this i didint buy it.
İt is not a very quality brand but it could done the work,
İ am using plexiglass glasses when i using theese and the little spinner.
YuGun
Postby YuGun » Mon Jan 10, 2011 8:01 pm
The axle is my car's rear axle, You can found it Renault 9 and 11 series,
İn America i dont know can you find a Renault but it would be the same rear axle with Delorean, (Back to the future car)
YuGun
Postby Woodstramp » Mon Jan 10, 2011 9:57 pm
YuGun,
Must have missed your chop saw....that is awesome. Beats the cut-off wheels by a mile. I did skip some pages, admittedly.
I would just run down and get a Delorean, but they use an expensive fuel.........cocaine. :o
Can't wait to see your finished rig. Cool work and thanks for sharing.
Woodstramp
Postby Cliffmeister2000 » Tue Jan 11, 2011 12:19 am
YuGun wrote:Image
THAT is a very nice piece of equipment! :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby YuGun » Wed Jan 12, 2011 2:58 am
Thanks Alot,
YuGun
Postby YuGun » Wed Jan 12, 2011 2:59 am
Bugün biraz boya yaptım.
Some paintjob done.
YuGun
Postby S. Heisley » Wed Jan 12, 2011 11:00 am
It looks good. That should help keep it from rusting.
Postby Steve_Cox » Wed Jan 12, 2011 12:12 pm
Are the neighbors enjoying the construction?
Steve_Cox
Images: 196
Postby YuGun » Wed Jan 12, 2011 5:16 pm
Thanks Heisley, İ hope it.
Thanks Steve,
My neighbours is impressed with it, This would be a neigbourhood project, Everyone looks it and show it their guests etc.
YuGun
Postby YuGun » Fri Jan 14, 2011 11:06 am
Bu hafta çok yoğun geçti doğrusu, Nasıl geçtiğini anlamadan baktım yine cuma gelmiş, Hemen eve geldiğim gibi hava kararmaya başlamasına rağmen dışarı çıkıp geçen hafta kestiğim kapı parçalarını taşlama ile birleşme noktarını taşlayarak çapaklarını alıp düzelttim,
Yarın kapıları toplayacağım kısmetse,
Selamlar,
Bu arada önde yapım sırasında kolaylık olsun diye açık bıraktığım kısımlarda eksik iskelet parçalarını da yerine tutturdum. Yarın doğrudan kaynaklayacağım. Bu arada yine elektrot almam lazım zira 4. 100'lük kutu elekrotumu bitirmek üzereyim. Eksik malzemeyi cumartesi almazsam pazar bulamıyorum. Bir yapım haftasonuna daha başlıyoruz.
Mevlana'ya göre gönüldeki her ferahlığın sebebi bir sıkıntıya bağlıymış, Umarım.
YuGun
Postby YuGun » Sat Jan 15, 2011 10:53 am
Ve bugün kapıları toplayıp yerlerine uygun ayarladım. Aslında sadece kapıları yapabildim çünkü sabahtan sanayiye giderek biraz malzeme aradım,
Üst kapağın kilitleme mekanizmalarında kullanacağım gergili kilitleri ve gazlı pistonlu yayları bulup satın aldım,
Eksilen elektrod tiner vb malzemeleri tamamladım. ve sonrasında eve gelip hemen işe başladım.
Hava geçen haftaki gibi güneşli ve güzeldi, İyi bir çalışma günü oldu. Kapıları tüm parçalarıyla beraber toplamayı başardım. Birkaç rütuş işi kaldı.
Sonrasında yerlerine monte edilecekler. Fotoğraflarda kapıların yerine öylesine konulmuş halde görüyorsunuz. Bir kazaya yol açmasın diye üstten lastikle bağladım.
Yarına kadar mecburi molamızı verdik.
İ have gone to industrial district today to buy the hintch of closed and locked the roof popup and the gas spring that could push up to it and open.
Then i came home and begin to making the doors you can see the doors frames put their where but not attached yet, Only put.
That is all that i could do this beautiful day.
YuGun
Postby YuGun » Sun Jan 16, 2011 10:32 am
Bugün çok çalıştım, Hava sabahtan itibaren kapalı, Soğuk ve 15.30'dan sonra zaman zaman da yağmur yağdı,
Kapıları bitirme düşüncesiyle hiç durmadım, ve nihayet bu amaca ulaştım, Bir tek ilk açılan (sağ) kapının kilidinin montajı kaldı, O da daha sonra yapılabilir,
sonra boyanacak ve hazır.
Böylece bir haftasonu daha geride kaldı,
Kapılar ikisi de tam açık,
Yarım açık,
Birisi kapalı
İkisi de kapalı
Genel görünüm.
YuGun
Users browsing this forum: Bing [Bot] and 10 guests
