Where are the pics Ron?
RandyG wrote:Kc, I shot a nail into my knuckle last month and hit didnt set into the wood so I also hammered it into my knuckle. So I second your advise.
Ron Dickey wrote:
I have a dilemma coming up.
a. After the Trolley walls have been cut and shaped
b. I will need to cut the cross bars that will attach to the sides of the trolley between the front and rear cross bars. drill holes in the trolley side for screws to be attached in to the ends of those studs. Then removed the screws and bars.
The ends of the trolley will rest on the roof at the ends carrying most of it's weight.
Before the trolley is put in place, I will need to.
1. The roof (cut in the middle for the trolley to drop in) must be put down first. The roof will be resting on the front and back cross bars at first.
2. Now the trolley rests on top of the roof and the same cross bars.
3. That done now I will need to place the cut cross bars
3a. these bars must go under the roof with the ends resting on the side of the trolley top wall and be glued and attached with screws though the previously drilled holes.
I will try and add pictures later to better explain.
Ron
MrMatt wrote:Hey Ron, just a quick note to tell you I have been enjoying following your build. Keep up then good work.
