Yesterday I used the dremel with a sanding disk, this is on a round cylinder with a small sanding disk held on with pressure.
http://www.dremel.com/en-US/Accessories ... ding+Bandsthe problem I found was in so being a small place when I was trying to keep the flat areas flat at the corners I would go to far in and have an shape not like I wanted.
Now I will have to add wood putty or filler or Bondo to the area and try and flatten it.
building this Trolley top is a little like building a miniature teardrop sides top but with the shape and planning it out just the same.
So now I am working on 4 projects.
!. the Arch almost done.
Put in insolation at the top of the curve today getting ready for the top to be put on. there is a lot of space above the insolation and it might shake loose so I will run tape over it and staple the tape to the wood to keep it in place. waiting to install inside wall and ceiling.
2. the trolley
cut to design needed windows cut and tapered so water will run off on to the roof below.
inside where roof vent will go is drawn with where supports will go for roof, and vent. Also support bars for the roof above the trolley have been drawn in too.
outside of trolley placement of where the trailer roof support studs will go has been drawn in. (pictures to follow)
3. the main Body
wall support studs in place up to the beginning of the galley are in place. Wiring has been held back until studs are in place for the roof so wholes can be drilled for wires to go through. One side has drawings on it for door and hatch cuts. Need to buy other side and 1 or 2 inside walls. ( I have one inside wall but it may cut up for the inside arch wall and maybe trolley roof or saddle bag curve parts. ) Plan as I go project.
4. Wiring
non started wires for trailer stop and clearance LED lights are bought except for the back fender lights. Plug and most of the wires are ready for install. However the wall and roof clearance lights must have a white ground wire to work. I have not gotten that but plan to this week.
Battery placement will better be known when saddle bags are built. Battery size and clearance is an issue.
Reading lights DC (cigarette lighter type female) and AC plugs have not been purchased nor have boxed to hold them.
Connectors for running PVC pipes have be bought for under trailer wiring. This is not needed but I just want to do it.
5. Saddle bags
design is basically done. want to make of wood will need to start on that as soon as walls are up.
6. Galley
Design 3/4 done. top cupboards still being worked on. have one set of pull side brackets need to buy 2 or 3 more.
need to design pull out for cooler and stove, pull out and insert for sink, what to put on counter top (sheet metal, tile, Polyurethane )
Swing out support shelves for side of trailer will need to be measured before designed (must have galley mostly done for that)
now I know I left something out?
am I talking to much
Ron
