TwilightLane Cubbie Build
Postby TwilightLane » Sun Nov 21, 2010 10:51 pm
Aspen enjoying some fall sun.
Rob & Lori
Aspen & Tundra
My Instructable: http://www.instructables.com/id/Teardro ... l-Trailer/
TwilightLane
Postby TwilightLane » Sun Nov 21, 2010 10:52 pm
Latch the door:
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Nov 21, 2010 10:53 pm
Bought some #10 gauge. Starting to hook things up.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Nov 21, 2010 10:55 pm
I ran the #10 through some conduit I had. Not positive how to do that turn as clean as I like. Mounted the master cut-off switch.
You can see where I jacked up a cut by 1/2 inch. Still cannot figure out how I did that. Geez.
Rob & Lori
Aspen & Tundra
TwilightLane
Here is how the battery box will sit.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Nov 21, 2010 11:25 pm
Face of the closet. I'll attach the LED spar and add a switch over on the right side.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Nov 21, 2010 11:26 pm
Switch installed on the attic. On the right.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Nov 21, 2010 11:29 pm
I also wired the 12-volt outlets in the attic. And chased them into the walls. Turned our pretty sweet.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Sun Nov 21, 2010 11:35 pm
I had the idea to line the 'attic' with felt. I thought that would reduce things bouncing around and keep sound down. My wife had some red left over from some project. I used a hot glue gun to attach it. Came out pretty cool.
I created some partitions too. Then polyurathaned them with the same stuff I used on the interior.
The partitions are just wedged into place. I want to maintain access in case I need to yank out the LEDs and fiddle with them.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby S. Heisley » Mon Nov 22, 2010 11:36 am
Twilight:
:o I don't think you can sit a battery on end like that. I'd worry that acid would spill out. If you're using an AGM...maybe; but I'd ask the manufacturer first with whatever type of battery you are planning to use.
Making a turn with your pipe can be done using a PVC elbow fitted to your pipe...even a sprinkler PVC elbow would probably work okay.
Postby S. Heisley » Mon Nov 22, 2010 9:59 pm
Wait! I think you got me! :lol: The picture is on it's side, isn't it!?! :lol:
Postby TwilightLane » Tue Nov 23, 2010 12:09 am
Ha! Sharon! Thanks for chiming in, yeah I posted the pic sideways somehow. The battery box will sit on it's base, normal-style, in the corner. No fancy on-its-side business. Thanks!
:lol: :lol: :lol:
Rob & Lori
Aspen & Tundra
TwilightLane
Postby TwilightLane » Tue Nov 23, 2010 12:21 am
Sharon, now people will think we are crazy. I just rotated the original pics in Photobucket, so they appear correctly in the thread. Instead of sideways like before.
:lol: :lol: :lol:
Rob & Lori
Aspen & Tundra
TwilightLane
Postby S. Heisley » Tue Nov 23, 2010 9:50 am
:rofl:
Postby TwilightLane » Sun Dec 05, 2010 9:31 pm
A lot of progress this weekend. I installed the headliner/ceiling on Saturday. I was worried about bending the luaun but it went very smoothely. In fact, I did it entirely myself - I thought I would need some extra hands to help me make it come together.
One of the steps I took was to apply the polyurethane stain to the sheet while it was already slightly bent. Here is my high-tech jig that I used:
Another view:
If you look close, you can see how the stain ran and puddled into the middle of the sheet. Fortunately that part will be hidden by the shelves.
Rob & Lori
Aspen & Tundra
TwilightLane
