StandUpGuy wrote:I installed the wall mount for my mini tank water heater today. The mini tank has one issue and that is the need to remove the tank at the end of the season to drain it of water. so in order to do that the plumbing must be diesngaged from the unit. I am exploring just how I am going to make that as easy as possible. Here is a photo of the mounted tank with some plastic pipes dry fitted in place. I have to unscrewable unions in place but there will be an issue. The unit has a mount that requires it to be lifted up about an inch from it to release the tank. If pipe is attached in the manner I have shown the pipes will hinder the lifting of the tank.
By justoneman at 2011-11-05
I cannot use flexible hose for the whole thing. I have the main water line coming into trailer. I have two faucets that are being served by the water heater. This requires a "TEE". It is not as simple as you make it out.starleen2 wrote:Save yourself some trouble and use the flexible connections - you could always put a loop in one to take up and "extra" length of the flexhose.
StandUpGuy wrote:I cannot use flexible hose for the whole thing. I have the main water line coming into trailer. I have to faucets that are being served by the water heater. This requires a "TEE". It is not as simple as you make it out.starleen2 wrote:Save yourself some trouble and use the flexible connections - you could always put a loop in one to take up and "extra" length of the flexhose.
