StandUpGuy wrote:The PEX would be good in that I would have a metal to metal connection. Still it is an increased expense with the crimping tool and all.
That's the easy part about sharkbite, no tools needed as it just pushes together.
ruce
My tank is directly over my axle. I was wondering about the bouncing and my fall back plan is a cinched strap around the unit. What I am most concerned about is the ease of removing the tank.If I had only a narrow door I would really be wrestling to remove it. This is the one thing that is a pain I am expecting in the mini tank unit.myoung wrote:I too have a water tank with that two-prong attachment system. However, mine is located on the front wall of the trailer where there is much less bouncing. I notice that the bouncing to the rear of the axle is much, much greater.
Isn't your water tank behind the axle? Only time will tell if the bouncing is significant there. If so, it should be a simple matter to put a wooden cleat above the heater to hold it in place more securely.
How will that work? Will you connect it to say the hot water outlet side and then undo the cold water inlet for the air break and then the pump will draw the water completly out? Have you tried this yet?myoung wrote:I picked up a simple pump that fits in the chuck of an electric drill that I will use to suck the water out of the tank after a trip. Don't want to leave water standing in the tank for months at a time. I have a siphon with a bulb to get the flow starting, but the pump should be much more efficient.
StandUpGuy wrote:How will that work? Will you connect it to say the hot water outlet side and then undo the cold water inlet for the air break and then the pump will draw the water completly out? Have you tried this yet?myoung wrote:I picked up a simple pump that fits in the chuck of an electric drill that I will use to suck the water out of the tank after a trip. Don't want to leave water standing in the tank for months at a time. I have a siphon with a bulb to get the flow starting, but the pump should be much more efficient.
That would be a pretty small tube then like an aquarium tube I guess. That would be a lot easier than hoisting out the tank with water and turning it upside down and holding it for an eternity while the water drains out. I am guessing my filled 4 gal tank would weigh like 70 lbs.myoung wrote:StandUpGuy wrote:How will that work? Will you connect it to say the hot water outlet side and then undo the cold water inlet for the air break and then the pump will draw the water completly out? Have you tried this yet?myoung wrote:I picked up a simple pump that fits in the chuck of an electric drill that I will use to suck the water out of the tank after a trip. Don't want to leave water standing in the tank for months at a time. I have a siphon with a bulb to get the flow starting, but the pump should be much more efficient.
I'll use the same siphon tube that I insert in the outlet. I have a 90-degree valve on the inlet side to stop water flow into the tank when dry camping and using the fresh water tank and pump. The air break isn't an issue because the siphon tube is has an outside diameter smaller than the inside diameter of the outlet so air leaks around it
