The Charlie Project
Re: The Charlie Project
Postby rebapuck » Wed Jul 17, 2013 12:58 am
I had a sailmaker do my awning. I got what I asked for. A 7x9 rectangle of Sunbrella. I neglected to account for the curves as the rail went slightly around each end of the trailer. Always had a sag over the door. Measure only the straightaway.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby Forrest747 » Sun Jul 28, 2013 11:11 pm
110334
Well the awning rail is installed. Tomorrow is fabrication of the awning.
Forrest747
Cowbell Donating Member
Images: 447
Postby Forrest747 » Sat Aug 03, 2013 5:54 pm
well the yard sale is going well. got rid of a couple of sleeping bags so it helped buy the vinyl railing insert. went with black, it works for me. looking at the sport nylon I am thinking of going with something heavier like duck cloth or sunbrella. the practice of fabric fabrication is going well. EMT conduit for the frame. Just need to figure attacment points on teh trailer.
110580
Forrest747
Images: 447
Postby Forrest747 » Sun Aug 04, 2013 7:41 pm
Worked on the awning supports today. i went with small footmen to hold the awning to the trailer. While at lowes i decided to go with white pvc. they had right angle and tees that were threaded. this i believe will make it easier to take down and store and i do not have to worry about gluing it just right. It also allows me to be more modular with the parts and the different types of awning or changing room. Ordered some keder rope and basting tape from sailrite and will be here later this week. been watching many sailrite videos on youtube on how to construct an awning. Thank you Sailrite.
110647110646110645110644110643
Forrest747
Images: 447
Postby S. Heisley » Sun Aug 04, 2013 10:02 pm
:thumbsup: Did Sailrite use PVC or is that your creation idea?
Postby Forrest747 » Sun Aug 04, 2013 10:07 pm
They used aluminum and other metal for the awnings. The pvc screw pieces made sense. Easy to break down and adjust
Forrest747
Images: 447
Postby Forrest747 » Mon Aug 05, 2013 4:47 pm
CHARLEY
Plywood 1/4 50
Plywood 1/2 100
Plywood 3/4 200
glue Gorilla 30
spars 2x4 50
lights 112
battery 89
Battery box 1 10
mattress 100
doors 40
roof vent 40
epoxy 150
screws 20
paint 60
fiberglass 10
converter 176
wire 0
fuse block 30
rails 40
wood 40
outlets 15
switches 12
12volt outlet 15
hardware 50
poplar 30
door latch 35
hinges 100
awning rail 50
vinyl 20
sink 90
tile 0
Epoxy Grout 50
cherry 264
water tank 100
grey tank 100
pvc 20
water pump 100
hose 20
fittings 20
steel 250
coupler 40
axel 275
rims 50
tires 200
running lights 100
windows 300
cooler 30
Fenders 70
Total $3753
If i make some changes that i learned from this build I calculate from the spreadsheet to build it for $2200. if i do things like cherry paneling then the cost goes up.
Forrest747
Images: 447
Postby Modstock » Mon Aug 05, 2013 7:19 pm
Let me know if ya need something sewn up . Oh, how did the trip go ?
Modstock
Re: The Charlie Project Awning Progress
Postby Forrest747 » Sat Aug 17, 2013 10:46 pm
111168
Some progress on the awning. I got the sewing machine to work. Bobbins i hate you. Ok that is out of the way. After getting the nylon hemmed and breaking two needles and getting the denim needle (who knew right) I sewed the keder rope to the nylon. its an ugly job and messed up in that about four inches of nylon bunched up and was sewed onto the keder rope. will need to be patched. I am sure this sewing thing will get better. a little worried about how stable it is really wobbly.
On the positive note I have found a Trader Joes so i am content with life.
Midnight update.
111172111171111170111169
Burning the midnight oil and now have the pockets for the pvc pipes and assembled for the first time. i like it. ok learned alot on doing this one and what not to do or make some workflow changes. going to try and do the next one tomorrow.
Forrest747
Images: 447
Postby S. Heisley » Sun Aug 18, 2013 7:47 pm
It looks like you did a good job, Forest. Anything more will fall under the "improvements" title, ey? :thumbsup: :applause:
What size PVC did you use? is that 1"?
Postby Forrest747 » Mon Aug 19, 2013 2:45 pm
I used 1/2 inch schedule 40 pvc. I am not sure how it will do and if it breaks i can always go bigger.
I can foresee an issue with how the rain drains off the awning but just going to see if it actually happens. Labor day here we come
You take the trailer out and something happens and you think i can change that or that is nice feature.
Forrest747
Images: 447
Postby Forrest747 » Wed Sep 11, 2013 9:41 am
108942 Here is the issue I was having with the contact cement. wasnt holding the vinyl in place.
112218 Using a half round trim piece I used brads to hold into place.
112219 the panel i made is too big and heavy for the four magnets so going to scrap it and start over. may use velcro
112221 pvc cross arms for the awning
112220 pvc legs for the awning as well I like how easy they are to screw in and makes it easy to adjust the angle.
Forrest747
Images: 447
Postby Forrest747 » Mon Sep 16, 2013 10:44 pm
9197291971
I messed up big with my windows. i ordered them from two different sources and did not get the right thickness and the trim rings were not going to work.
96163
So I thought ok Vinyl basic black with snaps would look great, great idea no way to figure it out. it came down to i had no idea how i was going to attach it to the wind itself to look seamless or at least nice.
112394112393
So spent the weekend making a couple of wooden window frames and used the trim ring as a guide and did my best to free hand it with the router. I still have an issue with one of the sides not sitting flush with the cherry paneling, in fact there is about 1/4 to 3/8 inch gap. will figure a way to fill it in. Next is the curtains I am pretty happy with it.
Update:
112528
Worked on the curtains and pretty happy with them. Just four simple panels, right now I am using bungee cords as the curtain rods.
Forrest747
Images: 447
Postby Forrest747 » Mon Jul 21, 2014 1:06 pm
I have blown up my lower galley inside. I do not use the water tank like i thought i would, and i need more storage space so i took it out. Along with the pump and some interior plywood. Going to have to redo the internal support for the drawer and protect some electrical (one wire did get sawzalled). Moved the battery to behind the cooler to the right, i still need to figure out how i am going to secure it. This was after a successful trip in southern Utah. I am also going to be removing the grey water tanks and rig up some sort of smaller drain line. Tons of fun and also new trailer logo
122643122642122646122640
Forrest747
Images: 447
Postby rebapuck » Tue Jul 22, 2014 12:03 am
Live and learn. Every time you go out, you'll be thinking of new and improved. I guess that's why so many immediately start thinking #2.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
