Compact family camper Build - Always something...
Re: Compact family camper Build - Campable!
Postby Rudyjr » Tue Feb 10, 2015 6:08 pm
BRAVO! :applause: :beer: Excellent job, I loved seeing the picture of the kids camping in driveway. That makes all the hard work worthwhile. Beautiful camper, Jim
Rudyjr
Postby S. Heisley » Tue Feb 10, 2015 9:59 pm
:thumbsup: It's a top-rated beauty! :thumbsup:
Postby pchast » Tue Feb 10, 2015 10:21 pm
Nicely done! :D
pchast
Images: 97
Postby ryuandwings » Wed Feb 11, 2015 6:03 pm
tony.latham wrote:I'm sooooooo impressed. This is one of those teardrops, that in my next life, I expect to see appraised on Antiques Roadshow.
t :thumbsup:
Wow, thank you very much.
I hope I built this sturdy enough so my family and perhaps my kids can enjoy with their kids for many years. 8)
ryuandwings
Images: 61
Postby ryuandwings » Wed Feb 11, 2015 6:07 pm
Rudyjr wrote:BRAVO! :applause: :beer: Excellent job, I loved seeing the picture of the kids camping in driveway. That makes all the hard work worthwhile. Beautiful camper, Jim
Thank you, Jim. :)
Hard tough work (although I enjoyed the most) was wiped away when my son was excited to camp in it. :thumbsup:
I hope to visit many places with this for a lot of great memories.
ryuandwings
Images: 61
Postby ryuandwings » Wed Feb 11, 2015 6:11 pm
S. Heisley wrote::thumbsup: It's a top-rated beauty! :thumbsup:
Thank you, Sharon. :)
Your suggestion about the bed corner turned out to be a great fix. It was so much easier to get in and out and that bed never got in the way. That corner of bed would have not added much useful space to the bed. :bowdown:
ryuandwings
Images: 61
Postby ryuandwings » Wed Feb 11, 2015 6:12 pm
pchast wrote:Nicely done! :D
Thank you very much. :D
So far so good. :thumbsup:
ryuandwings
Images: 61
Postby aggie79 » Thu Feb 12, 2015 10:32 am
Ryu,
You have created a beautiful teardrop and a wonderful family heirloom! I know you will have very many memorable occasions camping with your family.
Take care,
Postby ryuandwings » Fri Feb 13, 2015 10:32 am
aggie79 wrote:Ryu,
Take care,
Thank you Tom for the compliment.
Now that hard part is done, it is time to enjoy it. :thumbsup:
Waiting on the weather to get a little warmer... :twisted:
ryuandwings
Images: 61
Postby KCStudly » Fri Feb 13, 2015 12:28 pm
Fabulous job! I hope you get lots of use out of it as I am sure it will make a lasting impression on your kids. :thumbsup:
I'm curious, what would you say your biggest "lesson learned" was, and is there any one thing that you might have done differently? My guess, judging by your result, is that you pretty much nailed it!
Re: Compact family camper Build - Lesson learned...
Postby ryuandwings » Fri Feb 13, 2015 4:34 pm
KCStudly wrote:Fabulous job! I hope you get lots of use out of it as I am sure it will make a lasting impression on your kids. :thumbsup:
I'm curious, what would you say you biggest "lesson learned" was, and is there any one thing that you might have done differently? My guess, judging by your result, is that you pretty much nailed it!
Thank you :)
I was thinking about writing up a list of things I may change or do different, but since you asked, here are what I have so far on that topic.
a) Sometimes it is just not possible, but it would have made the build much easier if I had designed it to work with standard material and supplies sizes.
My trailer is about 5' wide x 10' long x 4'-6" tall. This creates a lot of waste materials building with 4x8 sheet goods.
Also, I wanted each aluminum trims to be continuous entire length, so some were 11' long. If I designed in a way I could use 8' sections, it would have saved a lot of trouble. I was not able to source items locally, so I either had to pay freight charge or road trip. (off course I choose road trip :thumbsup: )
b) This kinda relates to a), but working with 0.063 anodized aluminum was not easy. I didn't want it that thick, but that was only size I could find in 5' wide. Also, anodized aluminum is very easy to crack its finish. Bending is obvious, but you need to watch even when you clamp. Too much pressure at small concentrated area can damage the finish.
c) Nothing new, but check dimensions. There are several areas I had dimensional issues.
1) The exterior walls are partially bypassing the trailer frame, and that plus the tire size turned out to be not much space between wall and tire. This ment I had to get spaces. Extra cost.
2) I used lipped aluminum trim to cover most of exposed edges, but I did not account for the thickness of this lips. I know it is about 1/16ish, but that affected alignment of doors and hatch.
d) Don't design too specific for an item. I started out thinking about what I wanted in my trailer. PD405 for power, Camp Chef Oven/Stove in Gallery, window AC unit in tongue area, TV/DVD unit in Cabin cabinet, etc. Well it helps to lay it out, but when that item becomes unavailable it becomes a problem.
When I started, I was looking at 19" TV/DVD unit at Bestbuy and designed cabinet to house that. But now that perticular unit is discontinued and smallest they sell is 20". I think I can still fit 20", but it will be tight.
Also, I laid out galley based on Camp Chef Oven unit, but if I ever decide to go with something else, that space may not be wide enough. same with AC.
I know we are trying to squeeze so many stuff into very small space, but a little bit of wiggle room would help in long run in case you have to replace certain things.
e) Plan you build around climate. I really did not have much choice, but there are certain things would have been easier if I did in different season.
Epoxy, gluing, varnish for some reason, these work ended up in winter period. A lot of time I couldn't do because of temperature in the garage. Caulking and Butyl tapes would be hard to work with in winter as well.
I worked on trailer frame in the summer. I should have done that in the winter.
f) Plan your shopping. I have left out a switch from an order and had to order a switch at later time. $4 switch ended up costing something like $20 with shipping.
g) Budget for glue and fasteners. I totally left this out in my budget. You will use way more than you think. When I was in middle of certain work, I had to go store everyday to pick up screws, glue and caulking. Those add up quick.
h) Which leads to this. Try not keep all of your receipts.
I may think of more, but these are what I have so far. :beer:
ryuandwings
Images: 61
Postby KCStudly » Fri Feb 13, 2015 7:31 pm
Thank you for the very comprehensive reply. I have said many times that the only way to build a low price TD is to not keep track of your costs. :R
Postby Mike46 » Fri Feb 13, 2015 8:21 pm
Ryu, Who's vent are you using, it looks smaller than the full size 14" ones.
Thanks
Mike46
Images: 15
Postby ryuandwings » Fri Feb 13, 2015 10:31 pm
KCStudly wrote:Thank you for the very comprehensive reply. I have said many times that the only way to build a low price TD is to not keep track of your costs. :R
I have two separate books. One that totals everything and the one I share with my wife... :R
ryuandwings
Images: 61
Postby ryuandwings » Fri Feb 13, 2015 10:33 pm
Mike46 wrote:Ryu, Who's vent are you using, it looks smaller than the full size 14" ones.
Thanks
It's the manual galvanized roof vent I bought from eTrailer.com.
It is 14 x14. It seems like a little flatter than some of the plastic vent.
ryuandwings
Images: 61
