Atomic77 wrote:Thanks for the kind votes of confidence... It's much appreciated for sure.
I'm still up in the air for now about gluing the entire roof or just floating it... Big decision. From previous experiences I'v seen issues because of the glue or lack thereof, if it wasn't applied properly. In fact, notice most any RV out there that has Filon on it and look down the sides. They all look lumpy to me. So I'm probably leaning towards floating with a bead of urethane on the perimeter as Dale suggested. I'm going to epoxy and mold all the edges anyway. And with windows and roof fans, I'm sure there's plenty to hold it down. Decisions, decisions.
So anyway, feel free to offer your wisdom on this one. I would like to hear your thoughts...
I think your concern is quite valid. My feeling is that the issues with delaminating must be coming from thermal expansion difference between Filon and underlying plywood or other substrate underneath. Good glue is a big factor, but the real reason is stress created by the difference in thermal expansion properties between the Filon and material it is affixed too.
There is probably a good reason why manufacturer has published these numbers:
http://www.cranecomposites.com/pdf/7587.pdfSo Filon changes dimensionally at 1.7 x 10-5 in/in/°F or 31 µm/m/°C while plywood can be a lot less, up to 10 times. Say for 20ft long cover and 150°F temperature change, the difference could be around 0.55” if my calculation is correct, so if the skin fixed at the ends, I am not sure whether it is glue that will fail or glue and plywood can still expand together with the filon.
Teardrop roof (not the walls) is somewhat better in shape to allow for some of that expansion than straight panel like a house wall for example.
That is why there are slotted holes and special instructions for a house vinyl siding installation.
It would be a good idea to glue the Filon when the ambient temperature is in the middle of the expected future operating temperature range. That will reduce the movement potentially up to two times. Glue that allows some movement can be a good idea too.
