KCStudly wrote:With tubing you are only going to be able to weld from the outside, so welding the back side is a bit misleading.
KCStudly wrote:The angle of the bevel is not as critical...
KCStudly wrote:To me this looks like an issue of torch pattern and travel speed, and perhaps torch angle.
tony.latham wrote: I'm hearby certifying you as an amateur part-time welder capable of gluing up steel with globbed on molten steel.
tony.latham wrote:make sure you understand the warping problem with welding and how to mitigate it.
tony.latham wrote:... and get some advice. And not from me.
KCStudly wrote:My friend Karl and I used a hydraulic ram and jig table to form mine back true.
RandyG wrote:When riveting big pieces of skin, we were taught to start in the middle and work out, I guess it makes sense.
KCStudly wrote:Um... aren't you just a little bit worried that the hatch won't fit the cabin when you go to pair them up?![]()
lincolnlerner wrote:i am afraid that what he means is that the hatch will change shape and no longer match the td.
tony.latham wrote:When you do attache, how about screwing and gluing, and remove the screws prior to skinning?
