L'Escargot
Re: L'Escargot
Postby Steven.Cox » Sun Jul 29, 2012 6:36 pm
Time for a wall update...
After I used my new profile template to draw an outline of the profile on a 1/8" ply side, I began piecing together 1/2" Baltic birch plywood (no voids) to form an edge around what will become the profile.
Unglued raw plywood edge.
2012-07-28 16.18.44-small.jpg (65.13 KiB) Viewed 3745 times
My lovely assistant Alana (youngest daughter) cut biscuits in all of the contact points where 1/2" ply touched 1/2" ply. This greatly improved the strength of the sides and made them much easier to move around after the glue dried.
Alana cutting biscuits
2012-07-28 16.36.51-small.jpg (61.47 KiB) Viewed 3745 times
But sometimes mistakes are made...
Oops...
2012-07-28 16.58.38-small.jpg (34.9 KiB) Viewed 3745 times
On to gluing things together.
Steven.Cox
Re: L'Escargot
Postby Steven.Cox » Sun Jul 29, 2012 6:52 pm
So, I glued down the edges, making sure to cover the line that I drew with the profile template. I did not care how much excess was going to be cut off, I only wanted to make sure there was between 2 1/2" - 3" inches left behind. The inside of the wall does not have to be beautiful, only the edge.
Gluing down the edge of the profile
2012-07-29 10.36.04-small.jpg (52.62 KiB) Viewed 1666 times
I clamped things down like crazy and used weights when I could.
Detail of edge glue down
2012-07-29 10.36.16-small.jpg (51.6 KiB) Viewed 1666 times
Even with all that, I had two joints that were a little less than perfect, so I sanded them down to level them out once it dried. I do not want to end up with a bump when I glue the skin on the other side.
Edge mistake
2012-07-29 10.36.27-small.jpg (32.86 KiB) Viewed 1666 times
Waiting for glue to dry is a painful process.
Steven.Cox
Re: L'Escargot
Postby Steven.Cox » Sun Jul 29, 2012 7:07 pm
Cutting the sides...
I took my profile template and screwed it down to the side. I flipped it over and used a formica bit to cut the edge off... and forgot to take pictures of actually cutting the edge.
Formica bit
2012-07-25 18.10.24-small.jpg (40.32 KiB) Viewed 1665 times
Here is the finished profile. To cut the second side, I clamped the cut and uncut profiles together in two places on the bottom and one place on the top edges, and used the newly cut profile as the template for the second side. This assured they would match. So, now I have the profile for two sides cut.
Finished side
2012-07-27 12.16.34-small.jpg (23.53 KiB) Viewed 1665 times
And the edges are smooooth...
Smooth finished edge- look at that curve!
2012-07-27 12.16.52-small.jpg (21.52 KiB) Viewed 1665 times
Steven.Cox
Re: L'Escargot
Postby Steven.Cox » Sun Jul 29, 2012 7:18 pm
In between waiting for glue to dry, I decided to take advantage of the Harbor Freight sale that was going on for a couple of more days. I went to my local HF only to find they did not have the trailer in stock- folding trailer, 12" wheels. The woman behind the counter told me it was an Internet-only trailer and the sale price applied only if you bought it off the Internet. I live near Sacramento. There are several HF stores here, so I called the next one down the road. He told me she was absolutely wrong and they had exactly that trailer in stock... but could not sell them because of a problem with the title.
Reminding me of "Goldielocks and the Three Bears," I figured if the first bowl was too hot and the second was too cold, well, I should try the third...
Not giving up, I phoned the third store, half-way across Sacramento. They had three trailers. About 30 minutes later, they only had two!
Harbor Freight trailer
2012-07-28 18.16.32-small.jpg (52.79 KiB) Viewed 1664 times
At first I was going to build a trailer, then I decided to use HF, then I was going to build it again. I started thinking about it and decided I needed to commit. I want to keep this first trailer clean and simple, get it finished and go camping.
Steven.Cox
Re: L'Escargot
Postby campmaster-k » Sun Jul 29, 2012 7:53 pm
Dam Gathering or bust! Great work. Remember to reg. That trailer before you build on it.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: L'Escargot
Postby Steven.Cox » Fri Sep 28, 2012 12:52 am
So, it has been a while since I last posted. I need to do a little catch up...
I finally cut out the shape of the doors. I took 1/2 baltic birch plywood and built a frame with the shape I wanted and then used a router with a formica bit (my favorite!) to cut the 1/8 luan to the exact shape.
Profile with door cut out.
profile with door cut.jpg (42.76 KiB) Viewed 1601 times
Then I added more bracing inside the wall. I am going to put foam insulation in the voids. I put the bracing in so that I would have solid wood to screw into when I attach the interior wall between the kitchen and the sleeping area. I am also going to attach some things on the outside using this bracing as well.
Interior bracing.jpg (57.53 KiB) Viewed 1601 times
Steven.Cox
Re: L'Escargot
Postby Steven.Cox » Fri Sep 28, 2012 1:03 am
After I added some bracing, I cut foam to fit in the voids. I started out by dumping a bunch of glue where the foam would be attached.
Gluing the Foam.jpg (46.21 KiB) Viewed 1601 times
I quickly decided I needed a fast way to spread the glue, so I took a paintbrush I had for fiberglassing and sacrificed it.
Spreading the Glue.jpg (37.5 KiB) Viewed 1601 times
After the glue was spread evenly, I put in the foam.
Inserting the Foam.jpg (53.22 KiB) Viewed 1601 times
Will this foam insulate effectively? I don't know.
Does it make it lighter? Maybe.
Did it make the walls look cool while I was building them? Hell yes!
Steven.Cox
Re: L'Escargot
Postby Steven.Cox » Fri Sep 28, 2012 1:11 am
Time to glue the other side of the wall.
I traced the shape of the wall onto a piece of 1/8 luan so I would know where to put the glue and, more importantly, where not to put the glue.
Trace the Profile.jpg (36.9 KiB) Viewed 1600 times
Then I started dumping glue. I used a 4" paint roller to spread the glue out evenly and quickly.
Dump lots of glue.jpg (41.07 KiB) Viewed 1600 times
Here is what it looked like before I glued it up. If you notice, the profile leaning up against the wall had glue on the plywood frame as well. So, when I stuck it down, it really stuck!
Smear it all over.jpg (46.91 KiB) Viewed 1600 times
I sandwiched everything together and put a piece of particle board on top of it to weight it down while it dried.
Steven.Cox
Re: L'Escargot
Postby Steven.Cox » Fri Sep 28, 2012 1:42 am
Wow, look at those sexy curves! Once I finished my walls, I had to stare at them for awhile and decided to take a close-up of the curve detail.
Sexy curves.jpg (48.48 KiB) Viewed 1599 times
After all that work, I had to reward myself with some babybacks and copious quantities of my favorite carbonated beverage!
Steven.Cox
Re: L'Escargot
Postby campmaster-k » Fri Nov 02, 2012 6:48 pm
bump.
-Kirk
Build thread -
campmaster-k
Re: L'Escargot
Postby mallymal » Sat Nov 03, 2012 4:27 pm
Wow, you're doing some lovely work there!
Did you find the 1/2" ply chunky enough to biscuit into? It's what I'm considering using IF ever I get started :NC
I bet your finished tear will be nice n strong but not overbuilt bracing wise like some that you see.
Keep up the great work :thumbsup:
mallymal
Images: 18
