MrMatt wrote:I am just curious about the bamboo you are covering your trailer with. Is that a veneer? Is it easy to work with? Expensive?
kludge wrote:Wow, great build quality!
So... what are all those electric bicycles in the background?
theDangerz wrote:_Ryan_ wrote:theDangerz wrote:I bought frank's hurricane hinge. if anyone has installed the hurricane hinge with concealed screws (on the inside rather than on the roof), id love to see photos before the hinge arrives!!
Could you explain this a bit further? I've installed this exact hinge but I don't quite understand what you are speaking about. As far as I could tell there is only one way to install the hinge, although I have seen or heard of people who have installed the body side flange underneath the top skin on the outside.
I hadnt thought of installing the flange under the skin. if you could point me in the right direction of any examples that would be awesome.
when i was talking with frank he explained that it was possible remove both flanges (cut them off with a table saw) and instead of screwing through the outside you could screw through the face and effectively hid almost the entire hinge. I certainly don't see any examples of this in the galleries and was just wondering if anyone has tried.
Doug Hodder wrote:I routed a groove in the body portion of the tear and installed the hinge...I then overlapped it with the roofing material...I filled the "C" channel with a small hardwood strip first...this way when it is all said and done...I only have the crown of the hinge and the flap on the galley side showing....photo is prior to completion, but shows how it was layered....no leaks on it....just what I did....the aluminum skin is shown flapping above the tear....the sides were covered with maple framing and weatherstripping....not shown...but I built a woody....doug
_Ryan_ wrote:Looking great! I especially like the wood skin you are using!
As far as removing the flanges I think you might be getting into dangerous territory. The top flange on the body side is where the screws are installed. Removing this will leave you with only about a 3/8" wide flange on the inside of the body to install screws and support the weight of the hatch. The hatch side of the hinge is installed on the inside so this is less of an issue. Just my 2 cents.![]()
Looking forward to seeing more pictures!
_Ryan_ wrote:Looks amazing! I bet the epoxy will darken that wood up nicely.
Just a quick word on varnishes. I used both the Minwax Helmsman Spar Urethane (for the inside and galley), and Pettit Z Spar Flagship Varnish (for the exterior). This is an ongoing battle on this forum and I'm no expert but I caution you on using the spar urethane as it has far less UV inhibitors than a real spar varnish. When I compared the two the urethane was like like water and the varnish was like maple syrup. Realistically If your teardrop is garaged it shouldn't matter, but if it's stored outside you might want to reconsider.
Also the urethane won't build up coats as nicely as the true varnish, so make sure your epoxy is as smooth as you can get it before applying the urethane finish.
theDangerz wrote:_Ryan_ wrote:Looks amazing! I bet the epoxy will darken that wood up nicely.
thanks ryan
we went with a recommendation from the boat builders in our space and used schooner gold. maple syrup it is!
Ill get photos up as soon as i can
