We're finally beginning to cool down with the much welcomed cold fronts that we've been having lately... which means I've been able to make some pretty good progress on the TD.
I was able to safely install the 1/8" ply roof and fasten it with 18 ga staples and a little PL Premium. I've seen people fasten their roofs using screws but I think that's a bad idea if you're using 1/8" ply. The reason: 1/8" ply is so thin and flimsy that a screw driven and counter-sunk will basically have nothing to hold. Staples work great because a) their fast and strong, b) they can be driven with enough pressure to counter-sink into the wood, and c) they can be driven deep into the ceiling spars.
This past weekend I was able to completely fiberglass and epoxy the roof. I decided to go with 10oz fiberglass cloth as opposed to the 6oz that I previously had intended to use. I felt that 10oz cloth gave me the strength and rigidity that I needed to safely protect the flimsy 1/8" ply. However, I found that 10oz cloth is much harder to "wet out" than 6oz, which means, using more expensive epoxy and taking more care to wet out and not "starve" the cloth. All in all, I am happy with the 10oz and the way I see it, take time and spend a little more $ to protect your investment.
After the cloth was wet out I proceeded to do a re-coat every 2-3hrs. In all, I put about 4 coats on. Here's what I learned: 1) if you heat up your resin/ hardener with either a heat lamp or space heater, it will become less viscous, making the epoxy easier to spread and wet out fiberglass cloth. 2) folding 10oz cloth over edges even rounded to 1/4" is very difficult (I decided not to fold over the cloth, I may use thinner cloth as a tape on the edges. 3) if you use a brush to coat epoxy on a vertical surface, make sure to not put it on too think as it will begin to run and drip.
All in all, I'm satisfied with the way the fiberglassing came out. I will spot check the roof for any inconsistencies and re-apply epoxy where needed today before the final cure take place.
I used RAKA epoxy with the non-blush hardener.
Here is the seam between the wall and roof in which the 10oz cloth would not wrap around. I think if I epoxy the hell out of the seam it should work fine and be nice and water tight.
This is the Blue Sea fuse block which will run my 12V accessories
