Project "Willow" The standy trailer
Re: Project "Willow" The standy trailer
Postby Da'engineer » Wed Apr 22, 2015 3:55 am
I started working on the wall today for some reason I didn't take more then one picture... not exactly sure why.
But using the 2 in planks I cut down from the plywood I made the non-door wall side using pocket holes and tbIII
it's strong as rock
This is only the front portion the arc needs some sanding bad because I did a terrible job doing the outside the inside is very smooth surprisingly. Tomorrow going to fix that and get the inside 5mm ply attached and glued down.
Then on to the door side wall! Still having an issue with getting parts up here
Also I updated my excel sheet if anyone is interested to check that out...
And on a side note during this build
This mead is fermenting.. shorta my timer for my build it will be ready by the time I am done building ideally! :twisted:
Da'engineer
Postby Da'engineer » Sat Apr 25, 2015 1:56 am
FInished the door side wall inside today and rather then posting pictures like normal I thought I would give my time lapse app a go on my phone
:D!
Also got my new hitch in still have to mount it but got all the holes drilled.
Da'engineer
