Worked on a couple of small projects while the varnish dries. We mounted baskets under the door openings for shoe storage. These are metal wire baskets that slide onto a pantry shelf for more storage under the shelf. Using PVC pipe, the baskets slide in and out. During travelling, they'll ride inside the trailer.
Also under the door openings are LED lights for porch lights. We didn't want lights attached to the sides of the trailer so we found some lights used for mounting under RV awnings and screwed them in under the trailer. They shine out at a 45 degree angle and will light up the ground outside each door. I also found a remote switch for them. Using a key fob, the lights can be turned on and off.
I started attaching some 110V and 12v receptacles and did some wiring but have to wait for the big wiring job until the other side and the cross ribs get put back on.
With the colder temps it takes a little longer for the varnish to dry. Slowing things but we're still at it.
Bob
