I wish I was better at stopping and taking pictures while I work. I tend to just get so focused on doing stuff and keep working.
Anyways, so far I have:-Completed extending the plywood for both sidewalls
-Finished the template in OSB
-Cut and routed both sidewalls using the OSB template
-Routed out 1/4" deep area that the headliner and sparring will sit in
-Routed out a larger slot for a bigger piece of lumber that the hurricane hinge will attach to
Here you can see the sidewalls set in place. They are just leaning up against some five gallon buckets so I could get a feel for what it will look like. It's amazing how much weight that cut out when the walls are skeletonized.
- sidewalls.JPG (130.58 KiB) Viewed 2431 times
Next up:-First I need to seal the bottom of the floor with the asphalt emulsifier stuff (or whatever its called)
-Then I will attach the floor to the frame
-Then I will start cutting pieces for cabinets
-Once cabinets are cut I'll start assembling and gluing them
Hoping I have some more time this coming weekend to make some progress. I still haven't decided on how I'm going to finish it.
Anyone know if its possible to get a nice gloss coat that looks like a car finish on PMF?
