In so many ways I feel like this has been a lost weekend--which is quite unfortunate because I had Friday off. On the other hand, I did make some significant progress today. I guess to some degree I ust think I could have done so much more.
The week started with a trip to Dallas for depositions, I traveled Monday, had meetings Tuesday, and depos Wednesday. We wrapped up at 6:30 and I drove in home, arriving 1:30 am. I took the day off Thursday and spent the entire day preparing to lead a Passover Seder at my church. That, plus fill-in preaching last Sunday, and right there is a whole ton of lost build time. All that time, however, was very well spent! Both the sermon and the Seder went great. Friday I ended up spending all but about an hour cleaning up from the Seder then my grandkids came over to spend the night. No build time, but wow these are great things to do if you can't build!
We had the grandkids till about noon today then I got busy. I changed my profile--again, to Steve Frederick's Trailer for Two. I spent some time figuring out how to draw it on a 9x5 side instead of a 10x4 side. After drawing it off, I decided the hatch slope took up way too much room so I extended the curve. No geometric shape, jusy a fairing stick and "hey that looks good." The lovely and gracious Mrs. Nobes approved, so with much fear and trembling I cut the profile. I do pretty good--real good, actually--with straight saws. I'm decent with a band saw. I have never cut a good line with a jig saw. But, a new blade, a relatively new jig saw, and I did ok. I cleaned it up with 100 grit sandpaper in my palm sander (I am philosophically opposed to belt sanders) and decidedI could live with that.
Then I started taping lines for my cabinets and stood it up by my truck to check it out. I fit in there just fine. See for yourself:
I kept fiddling with the cabinets and ended up with this:
In the front, there is a lower 'headboard' cabinet we will use for books on bottom and toiletries on top. You can open the door, reach in and grab stuff out of the front cabinet. The upper exposed shelf will have battery-operated lamps and space for keys, watches, flashlights, and general pocket litter. I will install sliding doors since with the mattress there it will be impossible to open regular doors. No cabinets above our heads. Yes, that's a good idea.
In the back of the cabin, I have an upper cabinet for our clothes, then a lower pass-through cabinet that will open in the galley and the cabin. I don't know yet if this will end up as a galley or cabin cabinet--we'll see how it shakes out. Under that is an electrical chase. I'll use the Super Simple system described here in the forum and install two sets of outlets in the cabin and 2 in the galley. I will probably use wiring rather than extension cords, so maybe mine will be "quite simple" instead of "super simple." I'm confident I can get that done. Extending from the chase is an 8" shelf for phones, iPads, etc, ie, things that need charging overnight. Tail lights will be in the hatch. I will need to run the fantastic fan off shore power if possible. I will then run DC wiring for trailer lights, but will not use a DC system in the cabin. If the vent can't be run off shore power, when there is none we will open the vent and use a small battery-operated fan in warm weather. If necessary we can charge phones etc in the TV.
And the galley: on the countertop will be the microwave and the toaster oven. Below is a cooler on a slide out shelf on the right, a 4" vertical wine rack in the middle, with room to hang stemware on the top (not while we are traveling of course), and on the left 3 drawers: top for the stove, middle for silverware, bottom for pots/pans/dishes. Above the counter is a shelf for spices/towels/disposable cups etc, again, we'll see how that shakes out as we camp. Here is a sketch:
Then, list-maker that I am, I made lists of things to do, things to buy locally, and things to order. I am waiting on a check to come in before I can get busy with expensive stuff like fiberglass, etc. Hopefully, tomorrow after church I can pick up 1x4s to start on the skeleton.
So, while 'all I did' was cut out the profile, I also got my galley & cabin cabinets planned with dimensions and details and made lots of other detail decisions.
Plus I spent time volunteering at church and some great time with the best 2 little guys in the world, and those things are never, ever, a bad thing.
