New build 5' x 12' sleeping 4
Re: New build 5' x 12' sleeping 4
Postby LMarsh » Sun May 27, 2018 9:04 pm
DaveInConesus, I don't have a problem with that. I might talk your ear off about it though, but this my 4th build and I've sourced a lot of stuff both local and mail order. I'll actually be in Vitale park tomorrow around lunchtime if you read this. I can't seem to find the private message option though...Anyway we live in the Farmington/Macedon area and I only pop on this forum every so often. I've also had absolutely zero time to actually work on my build but I'm hoping to get on it now that I've wrapped up or postponed some other projects. I'm usually around and work weird off hours so most days would work for me.
LMarsh
Images: 187
Postby ELM » Mon May 28, 2018 11:59 am
LMarsh wrote:DaveInConesus, I don't have a problem with that. I might talk your ear off about it though, but this my 4th build and I've sourced a lot of stuff both local and mail order. I'll actually be in Vitale park tomorrow around lunchtime if you read this. I can't seem to find the private message option though...Anyway we live in the Farmington/Macedon area and I only pop on this forum every so often. I've also had absolutely zero time to actually work on my built but I'm hoping to get on it now that I've wrapped up or postponed some other projects. I'm usually around and work weird off hours so most days would work for me.
FYI There's no more (PM) private messaging any more. It has to do with some new laws on human trafficking. :? Sucks for us. :(
My Build journal. viewtopic.php?f=50&t=65395
ELM
Images: 176
Postby dancam » Mon May 28, 2018 12:23 pm
I was wondering what was going on. Is there a thread about this on the forum with more info? Are all our old messages gone? I cant acess them on tapatalk
dancam
Postby ELM » Mon May 28, 2018 12:53 pm
Here's where I found out what was happening when I couldn't PM.
viewtopic.php?f=26&t=70155
ELM
Images: 176
Postby DaveInConesus » Tue May 29, 2018 11:46 am
I didn't see this and just popped the same question over in my registration thread. I was down in Corning looking at Lauren's build on Monday. It is really nice. Can you send me an email at [email protected]? We can communicate that way.
Dave
DaveInConesus
Postby LMarsh » Tue Jul 17, 2018 9:19 am
Registering my build as a home made trailer was pretty easy. As discussed previously I called a couple local gravel yards and found one that would weight a trailer for $5. I brought in my landscape trailer to get a weight slip under 1000 lbs, brought everything to the DMV and told them it would have a 1500 lb GVWR, and it was a done deal. There was no difference in doing it this way than if I had weighted the actual build when it was just the frame. When I explained the to the lady at the DMV that I'd be sleeping in it she did say it could be registered as a house coach but that it would cost more. So she entered it as a regular trailer.
Finished the trim along the frame.
155302
155303
155304
This is my special order super low profile Fantastic vent that I needed to have clearance through our old apartment's garage door. Now I don't need it but it still helps and is much lower than their standard vents.
155305
155306
Installed the electrical for the DOT lights, interior DC and AC. I used a PD4135 and a 30 amp stainless Furrion inlet just so I could make use of certain RV accessories if ever needed. Its total overkill. I estimate we'll never draw more than maybe 10 amps DC.
155307
155308
155309
Looks a bit messy but I wanted to leave lots of extra wire in case I ever needed to move anything. I also don't have a ton of room but I did leave space for a battery. Although I don't think I'm actually going to put a battery in this compartment. I'm going to use a high amp trolling motor plug and socket to make having the battery more optional and easily moveable.
155310
Dimmer switches for interior LED lights and I also made the "porch" light dimmable. I want lots of light when needed but not all the time.
155311
155312
I'm clear coating anything not anodized or stainless. The baggage doors, entry door, and roof molding will be polished and clear coated. Here you can see the different between the baggage doors before and after I did a quick hand polish on the trim.
155313
155314
155315
155316
Its getting there.
155317
LMarsh
Images: 187
Postby Kim Armstrong » Wed Jul 18, 2018 3:32 am
Looking nice! I may have missed it but what did you use on the walls inside. Thanks
Kim Armstrong
Postby LMarsh » Wed Jul 18, 2018 7:59 am
I used a single 5' x 12' sheet of high pressure laminate on each sidewall and also cut smaller pieces to cover most of the interior framing/bulkheads.
LMarsh
Images: 187
Postby Kim Armstrong » Wed Jul 18, 2018 5:02 pm
Thanks. Looks really nice.
Kim Armstrong
Postby LMarsh » Mon Jul 23, 2018 11:50 am
Thank you for the compliments! I'm definitely not very artistic so I just try to keep everything fairly simple, clean, and smooth looking.
LMarsh
Images: 187
Postby LMarsh » Thu Aug 30, 2018 9:35 am
I finally have the trailer in usable condition even though its not finished. It still needs the pedestal table and benches, tongue box, interior trim work, bedside storage, and maybe some additional USB outlets. Little things like that. We took it out for 4 nights and towed it over 300 miles. It towed great and even at 60mph, a very bumpy highway, and rain, we had no problems. I think I accelerated my hair loss though since this is the first and only trailer frame I've ever made and it could have snapped in half 30 miles down the road.
Storage doors on.
155998
155999
Roof trim.
156000
I test fitted the bunk parts first then stained and assembled.
156001
156002
156003
156004
156005
156006
Fenders and welting going on.
156007
156008
156009
156010
156011
Entry door went on pretty easy with only minor modifications.
156012
Protective plastic peeled off and out in the sun for the first time!
156013
156014
156015
156016
156017
156018
156019
156020
156021
156022
156023
LMarsh
Images: 187
Postby pchast » Thu Aug 30, 2018 9:16 pm
Nice job. Looks like the happy campers agree...
enjoy! :thumbsup:
pchast
Images: 97
