Ok here we go...PMF!
Re: Ok here we go...
Postby KCStudly » Tue Apr 14, 2015 5:54 pm
dales133 wrote: ...Swamp marlin
Do it! :thumbsup:
Postby Sheddie » Tue Apr 14, 2015 9:05 pm
dales133 wrote:I've started thinking, even though I don't realy name inanimate objects that I should think of a name for this thing, something 4x4 and or fishing orientated.
Actualy I just had a bit of a thought as I typed this care of some "Sheddie "sarcasm. ...Swamp marlin ;)
Think of your roots mate and give it its full title, "The Hikurangi Swamp Marlin". :thumbsup:
Don't forget Mount Hikurangi (on East Cape) has strong cultural significance and the peak is traditionally regarded as the first land in the world to catch the rays of the new day's sun. We have our own smaller Mount Hikurangi here in Northland overlooking the swamp.
Think of the conversation starter the name would be when you are camping and you would no doubt attract a few Kiwis. :D
:thinking: I am being serious this time! :thinking:
Sheddie
Images: 1129
Postby dales133 » Tue Apr 14, 2015 10:37 pm
I'm thinking, I'm thinking...
dales133
Postby dales133 » Wed Apr 15, 2015 7:38 pm
I was just re organizing things out the back so I could cut some sheets up and decided to hook her up to the crusier and take it for a spin around the block.
She towed realy well and sat well hight wise to considering the land crusier has a 4 inch lift in total.
It's amazing how small it looks out in the big olé world ...I took some pics too!
dales133
Postby dales133 » Wed Apr 15, 2015 8:04 pm
dales133
Postby KCStudly » Wed Apr 15, 2015 10:22 pm
dales133 wrote:It's amazing how small it looks out in the big olé world...
I had that same impression when I wheeled my trailer out of the shop for the first time. It got small real fast! :lol:
Postby dales133 » Wed Apr 15, 2015 10:33 pm
Sure does! Even though mines tall it still looks dinky in tow.
I recon the shapes going to suit the curves of the 80 series nicely too.
dales133
Postby Sheddie » Wed Apr 15, 2015 11:47 pm
The Hikurangi Swamp Marlin is Lookin good :thumbsup: Looks to be spot on for height and width with the cruiser, and sitting level, should slipstream nicely :twisted:
It probably looks smaller at present because your eyes don't really see the skeleton frame under it. It will give quite a different appearance when the outer skin goes on. Although if it is all the same colour, with its height, it might make it look shorter.
Sheddie
Images: 1129
Postby dales133 » Thu Apr 16, 2015 2:09 am
Yea happy with ride hight and level Ness.
It will change a bit once it's got the cladding on but the bottom section won't be the same for the exact reason you mentioned, it would look way to squat.
But for an odd ball size of 5"4 wide and just over 9" long and 5 high including the subfloor it all looks pretty in proportion
dales133
Postby dales133 » Thu Apr 16, 2015 2:30 am
i put the front wall section of the ceiling/interor lining in today and it was a real bastard as i did it on my own.
its a tiny bit out on the radius where the sheet ends but not to bad and ill deal with it later when i fit the inbetween bit.
i also calked up the ceiling and sealed the back of the last sheet with a heavy coat of penetrating sealer, witch is now its second coat
dales133
Postby Atomic77 » Thu Apr 16, 2015 11:24 am
Looking really good. That bracing was my least favorite part so far. 49 of them! You're coming along really good. Remind me why you built in the height. I think you told me once and Carrie was asking but I couldn't remember. I told her it was to keep away the snakes and Tasmanian Devils! (She didn't buy it...)
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Postby KCStudly » Thu Apr 16, 2015 3:21 pm
I believe it was for under floor storage of things including prized fishing poles, IIRC.
Postby dales133 » Thu Apr 16, 2015 3:35 pm
Uh huh, I'm putting a slide out kitchen in a 5 foot draw on the left; fishing rods in the center and another draw for storage on the right.
At the front will just be 2 doors to adress the front section.
dales133
Postby dales133 » Thu Apr 16, 2015 11:21 pm
So I've got a problem...As I said yesterday I glued the front piece of ply inside on my own and in the process I've put a bow in one of the spars.
The one below it at floor level is straight and the one above it is pretty good as well.
I need to somehow de - bow it without it springing back as it currently is now.im considering building a tall ish curved topped box for the battery and fridge at the front and wondering if I might need to use this to hold the bow back or using some additional framing.you can see the spar in question in my previous pics...it's the second pic up.
It's probably bowed out by around 1/4inch
dales133
Postby Sheddie » Fri Apr 17, 2015 3:29 am
:thinking: I hate to say this now, but you wouldn't have had that issue if the sheet had finished on the flat and not part way through the curve. There are a few options to remedy this problem.
Looking at the exterior photo it appears that the spar at the top of the sheet is not parallel to the next one down, or is this the camera telling stories? How were you planning on having the two sheets butting together?
Sheddie
Images: 1129
