Chesapeake Light Craft Teardrop Trailer
Re: Chesapeake Light Craft Teardrop Trailer
Postby friz » Mon Dec 20, 2021 10:33 am
pchast wrote:I'm always impressed with your rig....
An Aside, I've been changing the CVT fluid In my outback every 25000. :thinking:
Mine gets brown and the coolant temperature raises by 10deg in that time.
Changing the fluid reduces coolant temp for several thousand miles before
it starts to creep up.
Good point. My Focus was one of the 5% sold with an old school manual transmission. 3 pedals. Any kind of small car with CVT or conventional auto may need some extra attention.
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sat Mar 12, 2022 9:11 pm
TestingImage
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sat Mar 19, 2022 4:53 pm
Fans!ImageImage
The "Sin Bin"
150133
friz
Images: 6
Postby aggie79 » Mon Mar 21, 2022 12:11 pm
Looks good!
Postby saywhatthat » Mon Mar 21, 2022 2:01 pm
just curious why didn't you get rid of those windows maybe install Wiley windows for the airflow
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby friz » Mon Mar 21, 2022 4:47 pm
saywhatthat wrote:just curious why didn't you get rid of those windows maybe install Wiley windows for the airflow
I guess I don't have a problem with them.
The "Sin Bin"
150133
friz
Images: 6
Postby saywhatthat » Wed Mar 23, 2022 5:25 pm
saywhatthat wrote:I guess I don't have a problem with them
That makes sense we had one come into the shop. They wanted to do some different Windows they said that those little vents weren't enough for air. I believe our Tech Guy ended up passing didn't feel that the door can handle the weight of a window Something about the water stains at the bottom of the door . Of the few that I have seen I like yours is the best you definitely spent the time to do it right
saywhatthat
Images: 135
Postby friz » Wed Apr 20, 2022 9:36 pm
Season 5 of camping bliss.Image
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sat May 06, 2023 11:33 am
Added the roadhouse tarp to the camping setup. Almost seems to be designed around the CLC teardrop.ImageImageImage
Sent from my SM-S906U using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby rcl57 » Wed Aug 09, 2023 12:34 pm
Great looking setup! I want to order my kit soon to have as a winter project. I do have two questions if you don't mind.
Appears you are running wheels, which I plan to do. Can you confirm and comment?
Also, thinking about the galley - can you provide the dimension from the ground to the lip of the top of the galley opening? I also like the cargo carrier for storage but think it may put the galley too high.
Thanks for your help!
rcl57
Postby friz » Fri Aug 11, 2023 8:28 pm
The wheels came from etrailer if I remember correctly. 12 inch. Same as stock for the northern tool trailer that they are on. Counter height is probably different than with the CLC trailer. I would not want it any higher or the doors for that matter. You do a lot of things sitting in the doorway on a teardrop. It's hard to put shoes on when your feet are dangling.
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Sun Jul 07, 2024 2:25 pm
A few addition to the camper for this season. First a receiver to mount a bike rack.
173722
173720
A new battery with a shunt and extra power for a 12v cooler. The screenshot shows power consumption for 15 hrs on a 100 ah battery.
173721
173723
The "Sin Bin"
150133
friz
Images: 6
Postby FischAutoTechGarten » Mon Jul 22, 2024 3:04 pm
Cool... I've seen some of your build on the CLC Tear Drop WordPress forum... but it's nice to see it fully documented here!!
FischAutoTechGarten
