Larry, here's where the "free time" is going now. I mentioned that I had a "few" things to do still, so here's today's work. I ran a ground from the inverter & ground strip to the frame per Rick's input from last weekend. No problems with faults, just being careful. The 110 volt, 12 volt & inverter are all grounded now, or earthed, as those who speak proper English would say.
The alarm system was never wired completely, so I spent part of the day working on trimming it out. It's all working now, but I have one thing to fix. I ran all the magnetic switches as "normally closed" in the doors, tongue box & hatch. WRONG! they should have been normally open, so an open door would ground the system & trigger an alarm. On Monday I'll go to an electronics store to buy a solid state relay to reverse the circuit & fix the problem. The spare tire is now alarmed & working since it's a (-) ground pin switch, the blinking LED is working & shows up in the port holes, the valet switch is functioning properly. The siren sounds when the spare is moved now.
Here's a shot of some of the alarm wiring & the gas pipe in the back behind the stove. The gas bottle sits in the A frame up front. I won't hook up the gas line until I have the alarm 100% set & working. I still need to test the line & fittings again, but it should be OK once things are hooked up.
I had a couple of hoses made at a local place which works on hydraulic & LPG lines near work. This is the back of the stove. The line is just looped into the back for safe keeping, but it shows the regulator & the line attached at the back of the stove & how it will sit when the stove is installed for good. The line has a loop in it since the stove tracks out about a foot to run. I got some Teflon & made rub strips on the galley floor, so the stove can't hop up & down on rough roads. Hopefully this will help keep the fasteners tight over time & prevent problems later on when using it. You can see them under the stove in the galley shot.
And finally, here's what the galley will look like when things are in place for good.
As you can see, the doors & drawer heads aren't made yet & installed. The inner skin for the hatch still needs to be put in, but I'm waiting to do the stereo & test it out prior to skinning the hatch. Want to make sure the speaker wires are right, as it would be a PITA to have to strip the hatch once it's skinned & trimmed out. The skin will be removable, but I'm not going there until I'm sure everything is working properly.
So Larry, does this answer your question? My "free time" isn't quite free just yet. Propane, stereo, TV & entertainment system, stereo, doors & drawers inside, curtains, etc. etc. etc. are still left to do....
