I spoke too soon about the inverter & power, my math is wrong! The 1,000 watt inverter needs about 10% to process voltage, so that's about 8 amps at full draw. Add the systems to it and it's a hungry little beast. It drew down the battery in a few hours and dropped out due to low voltage with everything powered. I guess the tree & its shadows don't help with charging either. No worries, as I'm going to order a smaller inverter (300-400 watts) to run the TV & entertainment stuff, since it doesn't need that much power. I'll keep the bigger one in place, in case I ever need to run something drawing more current. There's still lots of room on the bulkhead to mount another inverter. Live & learn I guess. Electrical & electronics were never my long suite anyway.
Worked on a TV antenna this morning. Used some gray 1" conduit & a cheap store-bought flat panel antenna (bow tie type). Works great! I get better reception in the trailer than we do in the house (adobe walls & several layers of wire lath are tough to get a signal through).
Used two U bolts, drilled through the tongue box side & fastened to the inside with hex nuts. Made a couple of wood spacers to block it out & plumb things up to make the mast sits right. The bottom one has a shallow hole it sits in & the top one just spaces the mast from the box & acts as a clamping surface for the conduit. I may do a longer one, but this fits in the truck & it works well enough for now.
